Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 04-18-2009, 01:21 PM   #1
moloveshisaudi1254
Account #: 160090
Default 1996 A4 2.8L EGR Valve issues.
Hello again to all AW members. I am having issues with my EGR valve in my 1996 A4 12v 2.8L V6. I have heard from at least two people on this forum that the EGR valve rarely fails and there is a way to clean it out. I would like to get some instructions on how to remove it and clean it out as I don't see any thing of this nature in the Tech. section. Also how long does it take for this part to get clogged and need cleaning once again?
Any help will be greatly appreciated. Thank you.
moloveshisaudi1254 is offline   Reply With Quote
Old 04-18-2009, 02:29 PM   #2
AudiMick
Account #: 37725
Default The pic is kind of big
I cleaned mine at 85K, 125K and 160K.
The problem is caused by "blow by" oil in the inlet tract.
As the car gets older the problem worsens as the engine wears.
In simple terms. You really need a manual for all the details.
You remove the EGR valve (you need a 10mm socket and a 22mm "crow foot". Remove the throttle body. Some have a torx some have an allen head.
Once these items are off take some stranded aircraft cable and run it down the passage. Put one end in a cordless drill and after pouring some gunk in the throttle body end spin the drill slowly.
Most of the "crud" accumulates at the throttle body end where it is cooler and the passage makes a right hand turn.
Spend at least an hour doing this. Last time I did this I put a cork in the EGR end and filled it up with Gunk and left it overnight to loosen everything up.
Re-assemble with new gaskets clear the code (or give it a few days to clear on it's own) and you are on your way.
2001 180 TTQ coupe
2003 A4Q 1.8T
1996 A4Q (sold)
AudiMick is offline   Reply With Quote
Old 04-18-2009, 04:42 PM   #3
moloveshisaudi1254
Account #: 160090
Looks pretty hard to take out because it is all the way back there. Did you have to loosen the engine mounts to move the engine forward to take it out or did you just remove the throttle body and reach in there? What kind of gunk cleaner did you use? Would dipping it in seafoam overnight have the same effect?
1996 A4 Quattro, 12v V6 (AFC)
Old 04-18-2009, 06:51 PM   #4
AudiMick
Account #: 37725
Gunk carb cleaner works.
All the stuff attached to the throttle body comes off including the cruise control, solenoid plate and plenum. Disconnect the vent pipes to the cam covers. Careful they are brittle after 13 years and they cost $$$.
It's tight but once the throttle body is off with a flashlight/ inspection light it's not that bad.
Not sure how you could dip it in seafoam without removing the intake manifold, that's what you are trying to avoid.
Gunk works just fine, just buy a large can, and while the throttle body is off clean up the throttle body and replace all the vacuum lines.
2001 180 TTQ coupe
2003 A4Q 1.8T
1996 A4Q (sold)
Old 04-18-2009, 11:18 PM   #5
moloveshisaudi1254
Account #: 160090
So your suggestion is to not take it off completely and work with it while it's in place?
Old 04-19-2009, 06:41 AM   #6
AudiMick
Account #: 37725
Remove the EGR valve and Throttle body.
Leave the intake manifold in place.
2001 180 TTQ coupe
2003 A4Q 1.8T
1996 A4Q (sold)
Old 04-19-2009, 05:34 PM   #7
MartinH
Account #: 19357
AudiMick covered that well. I also had to clean it on several occasions and, as suggested, take your time a do a decent job with the aircraft cable "roto-router" to increase the time before having to do it again. The cleaner the hole is the slower the future build up will be. Obviously, make sure the drill rotates in the correct direction (winding the wire cable up). And if you decide to replace the vacuum hoses, I suggest taking a photo first to ensure you put them back together correctly - there are a lot of them!
MartinH is offline   Reply With Quote
Old 04-23-2009, 09:05 PM   #8
jimrobertson
Account #: 96564
There is a vacuum hose guide on www.12v.org
jimrobertson is offline   Reply With Quote
Old 06-01-2009, 09:04 PM   #9
kwgerber
Account #: 163656
Default aircraft cable
what is this aircraft cable ???
kwgerber is offline   Reply With Quote
Old 06-02-2009, 05:54 PM   #10
AudiMick
Account #: 37725
Aircraft cable or wire rope.
Available at most hardware stores.
http://www.stageriggingonline.com/cable1.html
it's hard enough and abrasive enough to remove the sludge from the EGR passage when you rotate it.
2001 180 TTQ coupe
2003 A4Q 1.8T
1996 A4Q (sold)
1996, 96, a4, a6, audi, ck, clean, cleaning, egr, forums, issue, location, procedure, removal, valve
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
