Go Back   AudiWorld Forums > Audi Models > Audi A6 / S6 / RS 6 > A6 / S6 (C6 Platform) Discussion
Old 04-03-2009, 05:53 AM   #1
Grey Ghost 3.2
Account #: 102425
Default 45,000 Mile Service
I am going in for my last covered service next week. Is there anything I should mention to have them look at that they would pay to save me from paying for in the future?
Thanks
GG 3.2
2006 A6 3.2
Oyster Gray/Platinum
Sunroof, Premium Pack, Cold Weather
18", Nav, Heated SW
Grey Ghost 3.2 is offline   Reply With Quote
Old 04-03-2009, 09:42 AM   #2
pierreb
Cat Herder
Account #: 97649
pierreb's Avatar
get a local person to do a vag-com scan and see if you have any codes. for example, only a vag-com scan will tell you if you have an a/c leak before your a/c quits on you.
Cause I heard it in the wind
And I saw it in the sky
And I thought it was the end
And I thought it was the 4th of July
C.C. 1994
CAR-RELATED:
Wheel Scuff Repair | Tire Size Calculator |North Atlantic Audi Club | ACNA Northeast Chapter | Winter Driving School is fun! |
Her car: 2011 Audi Q5 PP+ w/Nav Quartz/Light Grey 2.0T 19"
Previous: 2005 A6 3.2 Tip Stratos Blue/Black
OTHER:
xbl: pierrebnh | Bernese Mountain Dog Rescue | How Not to buy a BMD | Scaler FAQ & more | Panasonic Plasma FAQ
pierreb is offline   Reply With Quote
Old 04-04-2009, 03:24 AM   #3
KevinGary
Account #: 89635
You should have a local mechanic put it up on a lift and do a once over. I did and I discovered slight oil seepage on the back of the valve cover gaskets. I complained to the dealer that I was getting oil drips on the driveway, which I was not. While they said it was hard to believe that the slight seepage was dripping all the way to the driveway, they agreed to change the valve cover gaskets under warranty.
KevinGary is offline   Reply With Quote
Old 06-28-2009, 04:37 AM   #4
divorce certificate
Account #: 164897
Clean & inspect all brakes, calipers & pads
- Adjust clutch arm travel
- Inspect suspension mounting bolts
- Inspect steering operation, tie-rod ends
steering gear box and boots
- Inspect all brake hoses, lines, cables
- Inspect parking brake and adjust
- Inspect exhaust pipe & muffler
- Inspect power steering system
- Replace radiator coolant
(45,000 miles or once a year-additional $30)
- Check tire pressure
- Inspect tires pressure and wear
- Tire rotation-wheel balance
- Change transmission fluid
- Road test
divorce certificate
divorce certificate is offline   Reply With Quote
2004, 2006, 2007, 45000, a4, a6, a8, allroad, audi, cost, manufacturer, mile, recommended, service, suggested, tt
Forum Jump
