#11 | ||
#12 |
#13 |
2000 Audi A6Join Date: Jul 2010
A kiddie swimming pool is a great idea. Even if you don't try to save that gas it at least allows you to dispose of it properly instead of letting it run into the environment and/or sewers.
Current: 2002 S6 Former: 2000 A6 4.2L |
#14 |
Might want to check first if gasoline won't dissolve whatever plastic the kiddie pool's made of as gas doesn't play nice with some plastics.
#15 | |
2002 Audi S6Join Date: Mar 2007
#16 |
2004 Audi A6Join Date: Apr 2010
Well, I successfully replaced my pump this weekend. I placed a large plastic open-top oil drain pan under the tank, and when I lifted the pump cover off the basket, fuel came out and washed over the top of the tank and into the container. I didn't catch all the gas, but most of it. As soon as the cover was free, I had an assistant at the ready with a flo-tec drill pump ($6.95 at Home Depot) which I had connected to a long 5/16 fuel line hose. I placed the hose into the basket and we sucked out enough fuel to begin the pump removal process. Yea, it was messy, but I had been w/o my car for over a week which resulted in the 'whatever it takes' mindset...y'know? I did not try to access the tank via the sending unit in the trunk. I did remove its cover and the black plastic ring, but then decided to proceed using the method above. This article from Robert Gedeon in 2006 was instrumental in getting this done. Thanks for all the feedback everyone! All hail the Audi Forums!
-IPStevieB
Steve B 2004 A6 2.7T S-Line "The last of the twin turbos" |
#17 | |
A drill motor has brushes. Brushes make sparks.... Sparks are not good around gasoline. Be safe and don't burn down your garage. |
| Tags |
| 1999, 2005, a4, audi, cabrio, cap, drain, easiest, gas, syphone, tank, tdi, touareg, toyota, video, vw |
