Old 04-02-2009, 05:08 PM   #1
webbtech
Default Need to drain gas tank
I have a 2000 A6 2.7T Quattro with a defective fuel pump. I have the replacement pump and need to drain the gas tank before starting. Everything I read in the forums assumes the fuel pump works and uses it to pump the gas out. Any suggestions for draining the tank when the fuel pump doesn't work?
webbtech is offline   Reply With Quote
Old 04-02-2009, 06:06 PM   #2
gubro30
Member
IIRC it is MUCH less dangerous to do that with a FULL tank of gas - gas itself is not explosive, however, an almost empty tank full of fumes is scary.
I would suggest syphoning it through the gas fill hole with a silicone tube.
gubro30 is offline   Reply With Quote
Old 04-02-2009, 06:56 PM   #3
WOWDee
Default Be Very Careful - No pilot lights or Trouble lights !!!! > > >
I once had to replace the fuel pump on a Toyota pickup. Siphoned a good portion of the fuel out just to make it a litle more managable but couldn't get it all out. Had to unstrap the tank and balance it on my chest as i lowered it to the floor noticed out of the corner of my eye the gleam of the pilot light of the furnace which was in the garage. Talk about seeing my life flash before my eyes ..... to use bad terminology. Whew! I quickly finished the job but without the pilot light on after a few prayers.
A friend of mine had her whole Honda Civic and their detached garage go up in flames when her father was replacing a fuel pump and the trouble light fell and broke igniting the spilled fuel. Luckily no one was hurt.
Couple of guys from my home town were driving an old pickup on a hot summer day. The old truck tended to get vapor lock and their fix was to reach outside the window and remove the gas cap(the caps use to be right behind the door on the pillar). A stray spark ignited the fumes and killed them both.
I know the last one is a little morbid ... BUT YOU CAN'T BE TOO CAREFUL!
WOWDee is offline   Reply With Quote
Old 04-02-2009, 07:20 PM   #4
BernieBenz
Siphon as much of the gas out of the tank that you can. No fun working with hands in fluid. The vapors in the tank will be at a concentration above the Upper Explosion Limit so are not explosive. So don’t worry, but don’t test it!
BernieBenz is offline   Reply With Quote
Old 04-03-2009, 12:19 AM   #5
Edd W
Agree, it is horrible and really dries out your skin and your hands will stink of fuel for several days afterwards. Draw off as much as you can, if possible leave none and aim to pick up any residue from the well in the bottom of the tank under the pump as well.
The obvious thing is to drive it until it is as near empty as possible but obviously, that is about as much use as the 'use the pump itself' method!
A8 4.2Tdi, 06, Grey/Grey - my new toy - how can a diesel be this fast?
2010 A4 2.0tdi 6 spd SE Executive avant - dark blue & Vanilla - Wife's new one.
VW Touareg 06 30k 6spd 2.5Tdi - Wifey's new one, A4 was not big enough!
A6 2.7t 01my 6spd Avant 51k miles - Sold Dec 2011 - Gone to Banbury
A4 2.0FSi SE 03.8 22k miles - Wifey's new one - the golf was not luxurious enough. Sold 30/08/08 - gone to Heathrow.
Golf Tdi 03.08 130pd, 6spd, 19k miles - Sold 8th November 2006 - gone to Coventry!
A6 2.8q 98.11 115K miles - sold 20th Feb 2006 - gone to Kidderminster.
100 2.8q 92.1 147k miles - Sold 6th July 2004 - its new home is Edinburgh
A4 1.6 97.8 99k miles - Sold 12th Feb 03
VW Golf Gti 86 22k miles 2.0 Oettinger 190bhp, lowered, lightened and quick and sold 23/03/08. Gone to Coventry.
Edd W is offline   Reply With Quote
Old 04-03-2009, 03:36 AM   #6
webbtech
Thanks to all who responded. However, siphoning won't work due to the screen at the bottom of the neck of the filler tube that prevents the siphon tube from getting down into the tank.
Any other suggestions?
Old 04-03-2009, 04:18 AM   #7
Edd W
Syphon once you have released the cover plate on top.
Old 04-04-2009, 05:04 PM   #8
01 2.7t
over half a tank of gas and it will spill out when you open up the tank .... get the gas out before doing so.. i didn't know that when i did mine and ended up with about 3 gallons on my garage floor.
01 2.7t is offline   Reply With Quote
Old 05-08-2012, 06:14 PM   #9
IPStevieB
2004 Audi A6
I have the same issue. 2004 A6 2.7t with a dead fuel pump and 12 gallons of fuel still in the tank. You CANNOT get a rubber sipon hose all the way into the tank because of a screen at the end of the filler neck...I have tried this. One person suggested removing the fuel filter lines and performing a slow gravity drain. What a PITA. I can do this, but was hoping for a better method.
Steve B
2004 A6 2.7T S-Line
"The last of the twin turbos"
IPStevieB is offline   Reply With Quote
Old 05-08-2012, 10:25 PM   #10
mithrilG60
2000 Audi A6
Try removing the sender cover in the trunk to access the tank from the top. You'll need long ciphon hose to access via the tank but it should work. Otherwise just put some cardboard under the car a SLOWLY open the fuel pump cover and let the excess fuel spill to the ground and hope there's enough cardboard the soak most of it up.
Current: 2002 S6
Former: 2000 A6 4.2L
mithrilG60 is offline   Reply With Quote
1999, 2005, a4, audi, cabrio, cap, drain, easiest, gas, syphone, tank, tdi, touareg, toyota, video, vw
