Go Back   AudiWorld Forums » Community Discussion » Firearms Discussion
Old 03-11-2009, 09:59 AM   #1
Parikh1234
Default keeping magazines loaded.....
just figured id ask what you guys think about keeping magazines loaded. I do this now in my safe within reach of the handgun.
A) What do you think this does to the spring in the long run? I know who cares cause its only 20 bucks to replace a mag but in terms of dependability.
B) keeping ammo exposed like that. My safe is humidity controlled if that matters.
C) keep it fully loaded or partially loaded?
Thanks.
vBulletin Sucks
Parikh1234 is offline   Reply With Quote
Old 03-11-2009, 10:05 AM   #2
oversteer
Guest
Default A) it wears the spring a little more, but you don't have to replace the whole magazine
when it wears out, you can just replace the spring
B) It's ok for it to be exposed, it's not hermetically sealed in its cardboard boxes either
oversteer is offline   Reply With Quote
Old 03-11-2009, 10:06 AM   #3
js0ne
js0ne's Avatar
Default Keep 'em loaded nothing to worry about.
you will wear out the mag spring faster from constantly loading and unloading than just keepng them loaded. (partial, or full it doesn't matter.)
The original 20 valve turbo has FIVE cylinders.
-Jason
js0ne is offline   Reply With Quote
Old 03-11-2009, 10:12 AM   #4
truth
Senior Member
Default Aactually keeping the spring compressed is not a big issue.
The repeated compression and release is what wears the spring out. More troublesome is the creep you can get as the spring pushes the first round into the top of the mag. It's one reason that the P-mags are so nice as the lid or cap keeps the first round in place.
Do not fear to be eccentric in opinion, for every opinion now accepted was once eccentric.
- Bertrand Russell
truth is offline   Reply With Quote
Old 03-11-2009, 10:37 AM   #5
JAFO
Member
Default i load 12 rounds in a 15 round mag.....
i've left them for more than a year with no signs of spring damage
'97 1.8tqms A4: apr stage 1, Miltek exhaust, K&N, SB/OFE clutch, S4 liner, apr snubby, bilstien hd, , h-sports arb's,cpp rear down links, autospeed dts, racetec strut brace, ecs 2 pc. A8 front brakes,pbr/axxis deluxe pads, goodridge ss. brakelines suspension hardware , sports mats, sunglass holder,
JAFO is offline   Reply With Quote
Old 03-11-2009, 10:41 AM   #6
js0ne
js0ne's Avatar
Default I usually keep them 1 shy of full capacity
for some reason I don't like how hard the first round is pushing up against the slide when at full capacity.
-Jason
Old 03-11-2009, 10:42 AM   #7
Parikh1234
Default yeah i usually load about 5 in my kimber 7 round mag, too much effort to get the last two in there.
vBulletin Sucks
Old 03-11-2009, 10:55 AM   #8
TabulaRasa
Member
Default Young's Modulus
I keep 'em fully loaded, except AR mags which have aluminum lips. AK is my goto gun anyway.
Original S4/S6 FAQ>
TabulaRasa is offline   Reply With Quote
Old 03-11-2009, 12:57 PM   #9
snoogins
Default Keep loaded, but I usually load 2 short of max (espcially with an AR mag)...
It keeps max-tension off the spring and insures that the gun will go completely into battery when charged.
snoogins is offline   Reply With Quote
Old 03-11-2009, 01:12 PM   #10
bostonasphalt2
AudiWorld Expert
Default compressing and expanding the spring will wear it dow faster than keeping it loaded.
bostonasphalt2 is offline   Reply With Quote
ak, capacity, compressed, compression, constantly, faster, keeping, loaded, magazines, release, repeated, ruin, spring, springs, wear
HTML code is Off
