Clicking noise when I hit brake, need help
Old 03-13-2009, 09:51 AM
al1375's Avatar
Default Clicking noise when I hit brake, need help
Hi,
I need help if someone ever experienced the clicking noise when you hit the brake, when I drive slow and start hit the brake I heard clicking (just one click, everytime I hit brake) noise that I can hear inside the car. The sound came from the front passenger side wheels, but I noticed there's nothing leaking or torn in front axles, Is it the wheel bearings goes bad that made the sound or something else? Thanks for your help.
Al
Old 03-14-2009, 02:45 AM
EBG 18T [Eric]'s Avatar
crap stuck in the brake pad?
Old 03-14-2009, 10:49 AM
TurboEnvy52's Avatar
Default Front passenger wheels? you ahve a 4x2? lol
Just sounds like some sand in the brakes...hit them hard one or two times, see if it stops!
Old 03-14-2009, 02:29 PM
Bob Petruska's Avatar
Default See my post down below....
You may have a brake pad come loose from the backing plate and this will give you a click.
Old 03-27-2009, 02:25 PM
rmonster's Avatar
does it sound like a clap? i think i have the same sound,everytime it happens, i imagined a clap between the brake pad and rotor, but im not even sure if thats the actual cause of the sound.
Old 03-27-2009, 08:42 PM
s4master1's Avatar
have you replaced the pads recently?
did you use aftermarket pads?
we see this type of sounds a lot and usually is the pads been shorter than the original parts
Old 03-28-2009, 11:01 AM
grocery getter S3+'s Avatar
Have you checked all the suspension bushings? I just had my car in with roughly the same noise, only at slow speed, and they replaced to 2 bushings and the noise is completely gone.
Not a cheap fix FYI.
Old 03-29-2009, 11:56 PM
Arimendiii's Avatar
I had a similar click in my car, and I checked everythin, but all was OK, untill one day, brake light came on the cluster, so I checked the brake fluid and the level was low. I refilled it, and since that day I never heard that click anymore. try this
Old 05-17-2020, 03:35 AM
JAHWORKS's Avatar
I’m experiencing something like that now.i have a 2011 q7tdi and just got my calipers painted literally three days ago.today when I was driving it was fine .i parked went into a store came out put the car in reverse and as I pressed the brakes all for corners gave me a clink sound(what sounds like metal hitting metal).it was just one clink not continuous.so what I did was put the car in drive and pressed the brake and all for corners gave me the same clink sound.so I figured if you’re going forward and want to reverse it will give that noise and vise versus because whatever the direction of the rotation of the rotors are at that time is changed it will give that noise .i thought the guy didn’t tighten up my calipers.i DONT know what it could be any thoughts ?
geri (03-04-2024)
Old 02-12-2024, 05:27 PM
Mzvan's Avatar
Default Audi q5 clicking noise when braking
which did they replace??? Thank you
Lukapalooza
14
06-30-2012 07:33 AM
UAE_Q7
Brakes Discussion
01-09-2009 02:55 PM
mikesd1980
04-08-2008 10:32 PM
kookie
11-10-2005 03:49 PM
opsya4
05-15-2003 07:27 PM
Quick Reply: Clicking noise when I hit brake, need help
