Go Back   AudiWorld Forums » General Car Discussion » Other (Non-Audi) Autos Discussion
Other (Non-Audi) Autos Discussion Discussion forum for non-Audi vehicles
Old 08-31-2008, 11:39 AM   #1
SlipAngle
Default diagnosing misfire
So I'm working on a friends Daewoo Nubira. I know...its a horrible car. But its got D-Tec yo.
I scanned it, got po300, random misfire. Then cleared the code, then ran it. CEL came on again and I got only po304, cyl 4 misfire. I had tested the EGR valve, its fine.
So I unplugged the #4 plug wire. Car ran exactly the same, no other codes.
So is it safe to say this could be a coil pack problem, or a plug wire problem? It has a single coil pack.
-Signature Space For Rent-
SlipAngle is offline   Reply With Quote
Old 09-02-2008, 07:19 PM   #2
eMKay (BFLO)
AudiWorld Uber User
Default Check the plugs first
President - AWOT Minivan BT
'02 Honda Odyssey
'03 Subaru Forester
'92 NX2000 (borrowed racecar, SCCA ITA)
'80 Hunter 27
'96 Hobie Wave
'71 Piper Cherokee 140
'76 Cessna 172M
'76 Piper Archer II
'77 Piper Archer II
eMKay (BFLO) is offline   Reply With Quote
Old 09-03-2008, 04:44 PM   #3
tpierce
Default single coil pack for all cylinders?
have it running, get a spray bottle with water in it. Spray the coil pack and see if you see sparks and can hear it misfire. If not, go to the wires. Also, if it's just the one cylinder, switch plug wires with another cylinder and see if it changes.
aim: tmpierce0000
tpierce is offline   Reply With Quote
Old 09-14-2008, 12:34 PM   #4
SlipAngle
Default I sent the injectors out to get cleaned and balanced....
as I had initially assumed that was the problem, due to the plugs in a couple cylinders looking very lean.
Turns out 2 injectors were functioning at half flow. They got cleaned/balanced, I put them back in, and ran the car. It fired right up and ran 10x better than before. It seems to have the normal amount of power, no more CEL's, but this is real weird. The car will just bounce off the rev limiter at 4000rpm while revving the car in park. I know this thing can rev more than 4000rpm.
Old 12-06-2008, 03:45 PM   #5
UrbanAssaultAudi
1988 Audi 90
Default not unless it sees road speed.
UrbanAssaultAudi is offline   Reply With Quote
2001, audi, diagnosing, misfire, misfires, s8
HTML code is Off
