Go Back   AudiWorld Forums » Community Discussion » Firearms Discussion
Old 04-22-2008, 07:11 PM   #1
PabloX
Default Can anyone recommend a good how to on break down, clean, lube and reassembling of an AR15?
Also, any recommendations on cleaning tools for one?
PabloX is offline   Reply With Quote
Old 04-22-2008, 07:41 PM   #2
snoogins
Default From memory...
Pop rear take-down pin...
Pull charging handle to the rear, bringing bolt carrier with it...
Remove bolt carrier...
Pop cotter pin from the bolt carrier, dropping the firing through the back of the carrier...
Push bolt rearward and remove cam pin...
Pull bolt from the front of the carrier...
Wipe down all parts that have carbon on them and lubricate them with the gun oil of your choice...
Reassemble in reverse order paying close attention that the gas rings on the back of the bolt are NOT lined up...
For cleaning the bore you'll need a good bore guide, available from any internet catalog that sells AR parts, and a coated steel or carbon fiber cleaning rod. You'll also need appropriately sized jags, cleaning patches and a can of Wipe Out faoming bore cleaner...
Follow the direction on the Wipe Out can, insert the charging handle and reassembled bolt carrier into the upper. Close the upper and push the rear take-down pin back through to secure the upper to the lower...
You're done. It should take you all of 20 minutes, if that long.
snoogins is offline   Reply With Quote
Old 04-22-2008, 09:53 PM   #3
green_vaccine
Default AR15.com has a whole forum about cleaning and maint...
buy the mil-spec cleaning kit, or at least one that comes with a bore brush.
"I hate to advocate drugs or liquor, violence, insanity to anyone... but in my case it's worked."
green_vaccine is offline   Reply With Quote
Old 04-22-2008, 09:55 PM   #4
green_vaccine
Default Takes me about 45-60 mins but I'm really OCD about it
Old 04-22-2008, 10:42 PM   #5
a_o_smith
Default you're better off being ocd with firearms...
whenever i start cleaning a gun the image of the exploded barrel they had hanging at the range of my summer camp pops into my mind... no really that related to cleaning but it keeps me motivated
Present:
2001 TT 225hp TQM, Valentine One, K40 laser diffuser, and an L7 in the trunk
2008 CBR600RR, Graffiti, integrated tail, F/E, PCIII & exhaust on the way
Past:
2001 ming 2.8
>>[?] means i have no idea what im talking about
>>My tech articles: tip recode for everyone, dissable running lights, O2 sensor replacement, Lemmiwinks explanation, TT sub install
>Questions on theses? email me: aosmith@gmail
>>pic poster
>>>Manual Tranny Tips, TT Front Plate Removal
>>>>Linkedin
a_o_smith is offline   Reply With Quote
Old 04-23-2008, 03:56 AM   #6
CC Rider
2009 Volkswagen Passat
CC Rider's Avatar
Default Otis
I was given one of these Otis cleaning systems as a gift. It came with a CD showing how to use the tools to clean from breach to muzzle. I think it's a pretty good system.
2009 VW CC
CC Rider is offline   Reply With Quote
Old 04-23-2008, 04:54 AM   #7
alms_TT_ny
Default I have a "reamer" that cleans the inside of the bolt carrier
it cuts away all the built up gunk deep inside where it's otherwise difficult to clean. Can't remember where I bought it.
alms_TT_ny is offline   Reply With Quote
Old 04-23-2008, 06:19 AM   #8
snoogins
Default That's VERY ocd. I didn't even take that long to clean my match rifle.
Old 04-23-2008, 07:19 AM   #9
PabloX
Default perfect, thanks.
Old 04-23-2008, 09:17 AM   #10
green_vaccine
Default Troof. Takes me about 45 minutes to clean my 1911 as well
HTML code is Off
