Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAD Discussion
Old 02-23-2009, 11:06 AM   #1
mike5
Member
Default 2004 Audi A4 11788 to 11852 Recode Question
So I'm trying to get the windows to roll up/down with the remote. I went to module 46 I think (Central Conv) and observed the value of 11788. I erased it and typed 11852 and hit recode. I can go back there now and observe that this new value is there. BTW: I did not see a "test" button or anything. Having done this, I still can't roll the windows up or down with the remote. What am I doing wrong or not doing? Do I need to start the car after recoding and drive it and then try again?
Thanks,
mike
Use the computer forum for computer/IT questions. -- AWOT's self-proclaimed PC expert.
Asadoorian Consulting
mike5 is offline   Reply With Quote
Old 02-23-2009, 01:10 PM   #2
mike5
Member
Default Update: Coding set, but no value under adaptation
I believe I'm supposed to see 95 in Adaptation #62, but nothing shows up. Should I just update it with 95?
Old 02-25-2009, 12:22 PM   #3
Darryl@HPAMotorsport
Default Sometimes when no value is seen under adaptation...
...it may be an indication that the ECU in question will not display the information. I have seen a few examples of this recently, where the ECU shows no value no matter what channel is accessed.
Nevertheless, I believe Mike5 has resolved this with a VAD software update.
Darryl Scott
HPA Motorsports / Versatile Automotive Diagnostics
604)598-8520 ext. 110
darryl@hpamotorsport.com
www.hpamotorsport.com
Check out our HPA Facebook fan page
Darryl@HPAMotorsport is offline   Reply With Quote
Old 02-25-2009, 03:16 PM   #4
mike5
Member
Default So far so good. Sent you an email just a little bit ago.
With a little time we'll figure out exactly what is going on!
Old 02-26-2009, 01:55 PM   #5
Default So far...anything new?
How's that software working so far?
Darryl Scott
Old 02-26-2009, 02:27 PM   #6
mike5
Member
Default I just tried...just for you!
I did the VAD on a sedan from previous and I can read block 62 and others using both versions of the software. So I don't know if something weird was going on with my Palm or what (all I can point to). I will repeat this on the Avant as well to find out what happens.
Thanks,
Mike
Old 03-19-2009, 08:39 AM   #7
drOopy01
Send a message via AIM to drOopy01
Darrryl,
I'm having this problem also! This is Rory by the way with the 2003 A4 1.8TQ. I recoded it to 11884 and was able to get the autolock function to work but the windows won't go up with remote when i press the lock/unlock button. Could this be because i haven't done adaption 62 with a code of 95?
drOopy01 is offline   Reply With Quote
Old 03-19-2009, 02:53 PM   #8
Default A4 Autolock function
Originally Posted by drOopy01 View Post
Darrryl,
Rory,
Please sned me an e-mail to darryl@vadpro.com with the applicable ECU P/N and I will check the procedure. The previous example was solved with a software update. As your version is up to date, I will look at other reasons. Thanks.
Darryl Scott
Old 03-20-2009, 06:31 AM   #9
drOopy01
Thanks darryl will do over the weekend.
Thanks!
1996, 2003, 46, a4, audi, button, forum, module, problems, recode, recoding, roll, set, window, windows, wont
HTML code is Off
