Help, car suddenly died while driving, cranks, but won't start.
Hi everyone. This is my first post, I hope I will get some responses. I have a 98.5 A4 2.8 Avant. Engine suddenly shut off while driving - no odd noises or things braking - just as if someone turned off the ignition. I tried restarting the car. It cranks, but doesn't start. I get this fault code with Ross-tech VAG tool:
Address 45: Inter Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop# WSC06325
1 Fault Found:
01383 - Alarm triggered by anti-Theft sensor: Front Right 35-00 - -
Questions:
Can this fault be responsible for the car not starting? (i.e. is the car alarm not allowing me to start the car?)
If so, how do I disable alarm, and/or fix this sensor (where is this right front sensor located?)
BTW, I can arm and disarm the car with the remotes and all seems to work fine.
If it is not the alarm, any other ideas? I thought it could be fuel pump/relay, but would not VAG show me a fault code if there was a fuel delivery problem?
The Bentley manual has virtually no info on alarm system and I searched the forum, but did not find anything.
Thanks,
Jack
Coding: 00102
Shop# WSC06325
1 Fault Found:
Questions:
Thanks,
Jack
had same problem: 98.5 1.8tq, GIAC and... (long)
was chipped when I bought. Had for 6mo. and shut off while driving. this continued to happen a few times a over a wk but would restart sometimes and not others. I wasn't able to check codes back then (over 3yrs ago)
sounds same as my situation. sent my ECU to AWE, got it back, worked for 24hrs, few starts later and same thing! sent BACK to AWE, they resoldered the chip in and no probs sense. (I know the current owner)
good luck!!
good luck!!
Re: Help, car suddenly died while driving, cranks, but won't start.
Check your Engine module for Coolant Sensor errors. I know it sounds weird, but I had almost the same problem. Mine didn't cut out, but it would not start after I shut it off. Just crank and crank and started after like 15 minutes. It turns out it was the coolant sensor. At first there was no CEL, but after one day there was. I confirmed this with other info and posts. Since it threw a CEL it was covered under warranty.
VAG-COM log:
Address 01: Engine
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D05
Coding: 06251
Shop #: WSC 06325
2 Faults Found:
16716 - Knock Sensor 2 (G66): Signal too Low
P0332 - 35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
Readiness: 0000 0000
VAG-COM log:
Address 01: Engine
Coding: 06251
Shop #: WSC 06325
2 Faults Found:
The only fault code I get is regarding the alarm. I replaced my coolant sensor a few months ago (had that infamous erratic gauge problem). I also checked the ecu - all chips are soldered and intact. I am baffled. sounds like a tow to the dealer. Thanks for the replies.
Avant Totinkle
VAG-COM Discussion
08-30-2004 06:59 PM
starting ...
06-02-2004 03:26 PM
kritzer007
05-02-2004 09:52 AM
