#1 | ||
MyFotki: Lots of Pics <u>2001 Audi TTQRoadster RavenBlack 2.2L->BT: </u> Motor: 2.2 forged Crank/Rods/Pistons, Girdle & deck cooling, Custom QEDpower Head with Schrick cams and Cat springs Forced Induction: GT3071R-WG-86AR-90TrimTurbine, DelRio Race Intercooler, DelRio BT Piping, Evo VFlo+ B5 S4 MAF, APR Bigport Intake ceramic coated, R32ThrottleBody, CoolingMist WaterMeth, larger injectors, fuelpump, etc DP-Exhaust: FastIntentions Custom 3”DP and Cat / test pipe section, BlackSheep Custom 3” cat back section with magnaflow resonator Suspension: VF Eng Mounts, KWV3+upratedfrontsprings, GroundControl C&C Plates, SpericalBushings ControlArm+Defcons+Poly, RearCamberBars, Uprated SwayBars Brakes: StoptechBBK 355 x 32 mm DriveLine: HaldexBlue + PeloquinRearLSD, SouthBendK70287FE Misc: Zeitronix EGT/WBAFR/Boost, Oil Temp/Pressure, Setrab oil cooler and oil filter relo, adjustable FPR/fuel pressure gauge Cosmetics: OSIR Fenders, SGI Carbon rear, 5PointHarness, race seat, custom front splitter, Black UFO, Black PC ValveCover, clear corners
#2 |
I run a mmuch larger set of cams w/no prob. Adj. gears are useful to move power band, not cure prob. you are referencing. If you used anything from EUROSPEC, TO ME THAT WOULD BE SUSPECT AT LEAST GIVEN THE 2 ENGINES i HAVE SEEN THEM SELL TO THE UNSUSPECTING. It may be that you need more coil, it may be the tune, was it done for the combination you are using? Need more info on your setup. Have you logged the problem w/a VAG tool? that is where you should start. Take it back to the tuner if nothing else shows up. Very few do a good job on large turbos IMO, check into Dahlback
Whole lotta car |
#3 |
Working with my tuner (remotely), and using vag com / scangauge. No the tune wasn't specifically written for this config, it's being adapted. thanks
#4 |
Whole lotta car |
#5 |
I know 014/015/016, for misfires, but what do you log for the cam / hall sensor?
| Tags |
| 252, 260, advice, b5, cams, eurospec, intercooler, s4, schrick |
