Go Back   AudiWorld Forums » Technical Discussion » Motors » Forced Induction Discussion
Old 07-04-2007, 08:48 PM   #1
gadgetmeister2711
Default 00 A6 2.7 Secondary Air pump Issues
Posted this in 2.7 forum, looking for an answer here. Keep getting error code on cold start, Insufficient Air Flow, Bank 1 and Bank 2.
I've gone through the entire system, all parts and hoses are working properly.
THE QUESTION:
Does anyone know what the computer actually monitors to determine if the airflow is sufficient or not? There is no actual sensor in the system, so it must be either cat temperature vs. time or upstream O2 sensor vs downstream O2 sensor comparison. I really don't want to start randomely replacing expensive parts.
Thanks for input.
gadgetmeister2711 is offline   Reply With Quote
Old 08-10-2007, 03:00 PM   #2
ub2slw
Default check the combi valve
here's a picture of the valve on my rs6... my guess is that the hose has deteriorated, like mine and isn't opening the valve...BTW its only for heating the cats faster when the car is cold...it won't affect performance. Check behind the valve covers between the engine and firewall
ub2slw is offline   Reply With Quote
Old 11-06-2007, 02:47 PM   #3
Vier Glühende Ringe
Vier Glühende Ringe's Avatar
Default Do you have 15inches of supply vacuum?
Vier Glühende Ringe is offline   Reply With Quote
Old 10-27-2008, 08:46 AM   #4
reddiamond
Default Re: 00 A6 2.7 Secondary Air pump Issues
most often it is vacuum problem a smoke machine is very helpfull . if you have access to vagcom activate soleniod and see if you can hear valve move (put a screwdriver on it).also i have opened valve with vacuum pump and activated air pump you should fell air out exhaust. have seen 2.8 cars with pluggrd passages in head
reddiamond is offline   Reply With Quote
1999, a4, a6, a8, air, audi, combi, forum, hose, hoses, location, pump, quattro, replace, secondary, vacuum, valve
HTML code is Off
