| RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4 |
#1 | ||
Junior Member
__________________________________________________ _______________________ 2006 RS4 Tourenwagen ![]() Mods: Chip Tuning (ChipCenter Sweden) Stasis Alcons, mono 6 370mm RS6 C6 356x28mm rear brake discs Milltek Downpipes Milltek Exhaust (Resonated) KW V3 Coilovers H&R rear sway bar Sabelt 6-point racing harness Braid Winrace 10x18" Dunlop Direzza 02G 265/35 18" Alcantara -08 owners' manual folder :) |
#2 |
#3 |
Brakes are all about front/rear balance and changing out your fronts to A4 rotors would destroy the balance. The A4 brakes are inadequate for the power of the RS4. Lots of other issues to consider.
#4 |
#5 |
Former Vendor
2001 Audi S4Join Date: Oct 2006
which controls proportioning. Haven't done any research on this, but it may be possible, it may not.
When going to ceramics the module must be coded to work with those units. Cheers, |
#6 |
Junior Member
#7 |
Junior Member
#8 |
Former Vendor
as that will control your proportioning. I moved from Porsche based brakes during the summer on my turbo converted 90q20v down to twin piston calipers so I could go back to 15" wheels for winter for several years. Just have to be aware of the changes in grip and fade resistance, however fade resistance with gummy snow tires when on snow/ice really wasn't a huge factor
![]() Cheers, |
#9 |
Junior Member
#10 |
What he is proposing involves using snow tires. Braking power is used against traction. Regardless of road conditions, most brakes out there will have the power to kick in ABS on the RS4 if it has snows on it. The fact is, snow tires cannot generate that much traction. Therefore, the limiting factor is not braking power, but traction. As long as the front/rear balance is sufficient, there would be no problem with this.
Fun is awesome. "Of all the extreme sports I've ever participated in- windsurfing, kite boarding, wake boarding, tow-in surfing and snowboarding- skiing, for me, made everything else easy." -Chuck Patterson |
