Go Back   AudiWorld Forums » Audi Models » Audi S4 / RS4 » RS4 (B7 Platform) Discussion
Old 09-04-2008, 09:01 PM   #1
Spurian
Member
Default Squeaky noises
My car had very few squeaks initially but it has recently developed some more and it is really annoying. Initially, only the back seat arm rest squeaked when it was open. I didn't worry about that.
Now there are some more noises. I am not certain of the source but it seems like the seat belt or some other place on the sides. I cannot pin point it.
Are these common? Are there any tips on identifying and fixing these noises?
Thanks
08/Audi/RS4/Lava Gray/Red-Black Audi Excl/Piano Black/TI/Tint
Spurian is offline   Reply With Quote
Old 09-05-2008, 07:34 AM   #2
MarkFank
Default My seat leather squeaks at shoulder height. Barely noticable but it is there.
Anyone else have this? Only on the drivers side. It sounds like there is plastic under the leather making the noise.
'08 RS4 Avus silver/titanium
MarkFank is offline   Reply With Quote
Old 09-05-2008, 10:02 AM   #3
loder
Default was just noticing the same thing today. hoping it goes away eventually
Current:
2008 RS4 - Daytona Gray | Silver | Carbon Fiber
1994 Miata - Black | Tan
Past:
2007 A4 2.0t
2002 A4 1.8t
2000 A4 1.8t
loder is offline   Reply With Quote
Old 09-05-2008, 12:27 PM   #4
GotRS?
GotRS?'s Avatar
Default Thanks a bunch, now I'll start hearing them!
Waiting for an RS5
GotRS? is offline   Reply With Quote
Old 09-05-2008, 08:51 PM   #5
greatwhiteshark
Default List of squeaks I've found and eliminated:
Some fixed with the help of this board, some due to hours spent in random Lowe's and Home Depot parking lots with random pieces of foam, felt, and the like. Hope it helps!
Location: A-piller headliner material creaking at driver/passenger grab handle.
Cause: Bolts under handle torqued too tight.
Solution: Loosened bolts under grab handle.
Cause: Headrest rubbing against inner shoulder section of seat.
Solution: Raised headrests two notches.
Location: Seatbelt rubbing/squeaking on leather seats and side of center console:
Cause: Seat design wider than normal
Solution: Audi/VW parts department "noise" or "quiet" kit comes with wraparound felt sticky pads that stick to the seat belt retainer and stops the rubbing/squeaking.
Location: Center console squeak at e-brake lever, plastic trim piece underneath it, and area around the accessory plug.
Cause: US-spec "cupholder design" instead of start button was a complete afterthought. Cheap plastic fitting tightly causes cheap-sounding creaking depending on temp, front passengers, and other variables.
Solution: Drench the parts with Gummi Pflege and then wipe off with a damp towel 1/2 hour later. This stuff lubricates the plastic pieces and quiets them for about 6 months at a time.
Cause: Cheap plastic, bad design for manual transmissions.
Solution: Move armrest up and back out of the way.
Those are the ones I've encountered. You can use the Gummi Pflege on the door and sunroof seals if they're making creaking noises too. The stuff is pretty amazing.
Some people have reported a dashboard squeak between the steering console and instrument cluster. I haven't encountered that one...yet. Touch wood.
Hope this helps!
-Matt
2008 RS 4 - Ibis White | 2003 S6 Avant - Atlas Gray
greatwhiteshark is offline   Reply With Quote
Old 09-05-2008, 09:30 PM   #6
Spurian
Member
Default Thanks! this is super helpful
rs4, seat, squeaky
