Go Back   AudiWorld Forums » Audi Models » Audi S4 / RS4 » RS4 (B7 Platform) Discussion
Old 01-29-2008, 06:27 PM   #1
ELEVENS
ELEVENS's Avatar
Default Help please - need VAG-COM Coding for Control Module 76 (Parking Aid)
Trying to turn off the Reverse confirmation beep in Control Module 76. My car has 0000304, seems like it should be 0000504. Changes won't stick.
Tried to change adaptation 10 channel 05 to "0" but changes won't stick either.
What is your Coding for 76?
______________________________
2007 RS4 Daytona Gray Pearl Effect
Silver Nappa Leather / Carbon Fiber Trim
Audi SuperSport Plus Suspension, GIAC software
No sunroof, rear airbags, resonator, or carbon (cleaned THRICE)
Only took 3 passes to run 12.5 @110mph completely smog legal on pump gas
2010 Q5 Deep Sea Blue Pearl Effect
Cinnamon Brown Leather / Brushed Aluminum Trim
[]S-Line w/ 20's, B&O, & hitch
ELEVENS is offline   Reply With Quote
Old 01-30-2008, 02:17 AM   #2
ELEVENS
ELEVENS's Avatar
Default Pretty please?
Old 01-30-2008, 04:37 AM   #3
OneEyedJack
Default Try recoding the module instead of using adaptation
0000504 should be the correct code. Instead of adapting a channel, try recoding the module with 0000504. It's possible that it won;t accept a zero value at channel 5 because the module is currently coded with the buzzer on. Just guessing though.
I'm sure you have seen RossTech's wiki but just in case:
OneEyedJack is offline   Reply With Quote
Old 01-30-2008, 07:26 AM   #4
ELEVENS
ELEVENS's Avatar
Default Thanks, tried that. I'll try posting over in the VAG-COM forum.
Old 01-30-2008, 05:39 PM   #5
ELEVENS
ELEVENS's Avatar
Default Still need coding for Control Module 76 please, also adaptation channel 05.
Mine are not what Ross-Tech says they should be and it would be a big help if someone with an RS4 could tell me what their coding is.
TIA
Old 01-31-2008, 03:37 AM   #6
PetrolDave
PetrolDave's Avatar
Default Tried looking at the Ross-Tech wiki? http://wiki.ross-tech.com
PetrolDave is offline   Reply With Quote
Old 01-31-2008, 04:52 AM   #7
ELEVENS
ELEVENS's Avatar
Default Yes and it appears wrong, that's why I'm asking for somebody's (ANYBODY'S!) RS4 coding
aid, audi, parking, rs4
