Go Back   AudiWorld Forums » Audi Models » Audi S4 / RS4 » RS4 (B7 Platform) Discussion
Old 05-01-2007, 02:23 AM   #1
RS4 SE
Junior Member
Default Milltek Hi-Flow cat vs OEM cat pic from weekend install.
__________________________________________________ _______________________
2006 RS4 Tourenwagen
Mods:
Chip Tuning (ChipCenter Sweden)
Stasis Alcons, mono 6 370mm
RS6 C6 356x28mm rear brake discs
Milltek Downpipes
Milltek Exhaust (Resonated)
KW V3 Coilovers
H&R rear sway bar
Sabelt 6-point racing harness
Braid Winrace 10x18"
Dunlop Direzza 02G 265/35 18"
Alcantara -08 owners' manual folder :)
RS4 SE is offline   Reply With Quote
Old 05-01-2007, 03:26 AM   #2
ESFO
Default Very interesting pic.
When I get to work I want to check the inside angle of that bend. Anyone know the cell count on stock cats vs. Milltek?
ESFO is offline   Reply With Quote
Old 05-01-2007, 03:45 AM   #3
ELEVENS
ELEVENS's Avatar
Default Thanks. Hey, where are you located to get an 06' RS4?
2007 RS4 Daytona Gray Pearl Effect
Silver Nappa Leather / Carbon Fiber Trim
Audi SuperSport Plus Suspension, GIAC software
No sunroof, rear airbags, resonator, or carbon (cleaned THRICE)
Only took 3 passes to run 12.5 @110mph completely smog legal on pump gas
2010 Q5 Deep Sea Blue Pearl Effect
Cinnamon Brown Leather / Brushed Aluminum Trim
[]S-Line w/ 20's, B&O, & hitch
ELEVENS is offline   Reply With Quote
Old 05-01-2007, 04:08 AM   #4
xr8edS4
Senior Member
Default Sweden
based on the email addy (.se)
07 RS4 Daytona Gray/Onyx
01 S4 Brilliant Black/Onyx...
6 spd Rowing Machines.
xr8edS4 is offline   Reply With Quote
Old 05-01-2007, 04:52 AM   #5
RS4 SE
Junior Member
Default Milltek is 200c and OEM is about 500c ?
Mods:
Milltek Downpipes
KW V3 Coilovers
H&R rear sway bar
Old 05-01-2007, 04:54 AM   #6
RS4 SE
Junior Member
Default correct
Mods:
Milltek Downpipes
KW V3 Coilovers
H&R rear sway bar
Old 05-01-2007, 05:33 AM   #7
Vijay
Default Interesting position of the stock 2nd Oxygen sensor compared to the Milltek.....
With the stock 2nd oxygen sensor in front of the main cat, it appears that the main cat is not involved whatsoever in ECU feedback regulation, only the pre-cats. Compare this to the Milltek where you have only one cat, and a pre and post cat sensor as one would expect.
Current Stable: Audi * Porsche * BMW
Vijay is offline   Reply With Quote
Old 05-01-2007, 05:55 AM   #8
S4gasbord
Default This is typical of aftermarket downpipes.
The second O2 sensor needs to read post-cat levels or the CEL will light up.
S4gasbord is offline   Reply With Quote
Old 05-01-2007, 06:27 AM   #9
Vijay
Default My comment was more about the fact that the stock downpipe DOESN'T have a post-2nd cat sensor...
This would seem to imply that in the stock configuration, only the first cat is involved in the ECU feedback mechanism, and that one could dump the second cat entirely from the stock exhaust without triggering a CEL?
Old 05-01-2007, 07:44 AM   #10
S4gasbord
Default Umm, it usually is only the first cat involved in the feedback mechanism.
But your comment about dumping the second cat without triggering the CEL is correct. Having said that, why would you want to retain the front cat that is so close to the turbine outlet? Better to get rid of the first cat and move the second O2 sensor behind the second cat.
cat, hiflow, oem
