TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
Break Pad Sensors w/Vag-com?
Old 02-27-2009, 10:35 AM
ShadeD1's Avatar
Default Break Pad Sensors w/Vag-com?
I swapped the stock pads for racing pads and have the brake pad sensor lit up on my dash. I bought vag-com to disable it. I was able to find the page for the Golf 5 platform (I assume that is my car's platform since I was able to use the micro-cam interface). According to the instructions on that page I should have been able to turn off the brakepad wear sensor by subtracting 1 from the soft coding changing it from 0049268 to 0048268 but it was a no go. Any suggestions? I've got an 08 TT 3.2
Old 02-27-2009, 10:40 AM
proport's Avatar
Default ...so your new pads didn't have sensors in them? should deffinately be able to vag-com it...
Not sure of the exact procedure, I can try to look it up for you though..
Old 02-27-2009, 10:48 AM
alipor's Avatar
Default You could just complete the circut, to get the light to go out.
Just cut the sensor off the old pads, leave a a few inches of the cord, strip back an inch tie them together, and plug it in.
Old 02-27-2009, 11:01 AM
ShadeD1's Avatar
Default Re: You could just complete the circut, to get the light to go out.
I already did that and it did not work
Old 02-27-2009, 11:08 AM
ShadeD1's Avatar
Default instructions from ross-tech.com...
I found the instructions below on ross-tech.com under Golf V platform. They look like they should work but I think they have the wrong code for breakpad wear sensors for my car. When i hit "code" to recode it I get an additional information screen with several codes and it looks like +1 is for something else (I think washer fluid low)so I bet they changed the code for my car. Unfortunately, brakepad wear sensors is not one of the listed codes
Removing Seatbelt Chime
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Look at the third and fourth digits in the coding (00??x0x). Add the values for the options together and put them in the third and fourth digit location to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active
+16 - Sedan (Jetta)
So, if your stock Soft Coding is 0023203 and you want to remove the seatbelt chime, put in a new value of 0021203.
[Do It!]
Operating Windows
Old 02-27-2009, 01:55 PM
ShadeD1's Avatar
Default Looks like it is not an option on my car :(
It seems likely that no configurations of your car were sold without wear sensors. You may want to install a jumper at the brake pad wear sensor connection since, per the label file, I don't see any Coding options that would allow you to remove the brake pad wear sensor monitoring:
C00,Instrument Cluster (J285) Coding
C01,????xxx: Equipment
C02,+0001 = 2nd Fuel Tank Characteristic (All-Wheel Drive)
C03,+0002 = Highline without DIS (for Midline PR-9Q3)
C04,+0004 = Manual Transmission (not Midline PR-9Q3)
C05,+0008 = 2nd Tire Circumference Pair (e.g. Winter Tires)
C06,+0016 = Tire Pressure Monitoring (TPMS)
C07,+0032 = AFS (Advanced Front Lighting System (cornering lights)
C08,+0064 = Magnetic Ride Suspension
C09,xxxx?xx: Country
C10,0 = Germany / 1 = Rest of World (RoW - Left Hand Steering) / 2 = USA / 3 = Canada
C11,4 = Great Britain (Right Hand Steering) / 5 = Japan (Left Hand
Steering) / 6 = Arabien States
C12,7 = Australia / 8 = Rest of World (RoW - Right Hand Steering) / 9 = Japan (Right Hand Steering)
C13,xxxxx?x: Seatbelt Warning
C14,0 = No Seatbelt Warning / 1 = Seatbelt Warning (EU-NCAP) / 2 = Seatbelt Warning (NAR Old)
C15,3 = Seatbelt Warning (NAR New) / 4 = Seatbelt Warning (EU-NCAP incl.
Passenger)
C16,5 = Seatbelt warning (NAR Old incl. Passenger) / 6 = Seatbelt Warning (NAR New incl. Passenger)
C17,xxxxxx?: Illumination & Washer Fluid Warning C18,0 = Needles OFF and Scales OFF (Term. 15 ON / Term. 58 OFF) / 1 = Needles ON and Scales OFF (Term. 15 ON / Term. 58 OFF)
C19,2 = Needles OFF and Scales ON (Term. 15 ON / Term. 58 OFF) / 3 = Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF)
C20,+4 = Washer Fluid Warning
lentiman
Q7 MK 1 Discussion
04-08-2019 10:39 AM
makav3li
Brakes Discussion
01-02-2012 05:56 AM
Divided
07-27-2009 06:11 PM
ShadeD1
VAG-COM Discussion
03-01-2009 03:16 AM
myers1.8TQ
09-21-2008 01:34 PM
Quick Reply: Break Pad Sensors w/Vag-com?
