Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk2) Discussion
TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-present
Old 01-11-2008, 09:04 PM   #1
PeaceOuTT
Default Trunk latch noise? Wind noise when going 60+mph
When you unlock the trunk (remote/trunk release) then close the front doors, it re-unlocks the trunk.
Does it happen to anyone else?
Also anyone else have to slam the trunk quite hard to get it to shut? It'd be nice to just drop it and have it shut and lock.
The wind noise from the driver side window is driving me up the wall. Anyone got a quick fix?
~PeaceOut
2008 Audi TT 2.0T DSG
PeaceOuTT is offline   Reply With Quote
Old 01-12-2008, 04:56 AM   #2
BMWBig6
BMWBig6's Avatar
Default I haven't noticed the trunk latch noise, but...
Yes it would be nice if the hatch lid would "suck" itself down if you brought it close enough to the latch. Though I wouldn't say I have to "slam" mine to get it to close properly and engage the latch. In fact, closing the hatch is very comfortable for me if I use the handle located on the interior of the hatch (vs. trying to press down on it from the exterior/paint outside the hatch.) When I use the interior handle, I do kind of a *fist pump* motion that pulls my fist (fingers facing up) in a swinging motion ending at my waist, and that really doesn't seem to take much effort to close the trunk. My wife seems to be able to close the trunk just fine too. If she can do it, nobody else can have an excuse. (Ok, if you're 90 years old and frail, I'll accept that, but then I would think closing the trunk would be the least of your worries because you would have way more trouble getting in and out of the car!).
Can't comment on wind noise, wonder if it's the mirror design/shape. Does your window automatically raise 10mm whenever you close the door? If it's not raising, that might explain the wind noise.
Ben
2009 Audi A4 2.0T S-Line Avant (1-of-a-kind in the U.S.)
2008 Audi TT 2.0T S-Line Coupe (1-of-a-kind in the U.S.)
2011 Ford F-150 Lariat Limited (#3252 of 3700)
Retired: 2003 Ford SVT Lightning / 2001 Ford SVT Lightning / 1993 BMW 740iL / 1990 BMW 535iM / 1986 Porsche 944 Turbo / 1983 Porsche 944
BMWBig6 is offline   Reply With Quote
Old 01-12-2008, 08:21 AM   #3
Jeffc31337
Default I find the wind noise VERY minimal. Much quieter than my old Acura TSX.
Jeffc31337 is offline   Reply With Quote
Old 01-12-2008, 02:50 PM   #4
RagtopDay
Default I also noticed the trunk latch noise you mentioned. And didn't get the
trunk closed hard enough to latch a couple times when I first got the car. I just figured it's a German car thing & learned to use more force when closing it. As a long time ragtop owner, wind noise is just part of life. This is the quietest droptop I've owned. And seals well, with no water intrusion during it's only auto carwash - touchfree of course.
2008 TTQ Roadster
1st Audi
Love this car!
RagtopDay is offline   Reply With Quote
Old 01-13-2008, 12:56 AM   #5
PeaceOuTT
Default Re: I haven't noticed the trunk latch noise, but...
Yeah I close it just like you mentioned. Using the handle on the inside of the trunk door.
It just required a bit more force than I thought it should. Would have been nice if it could just shut when it drops. I keep closing it too soft and end up having to reopen it to close it again. To reopen it you have to either press on the remote or hit the button on the driver door. There should be a hidden button back there.
The wind noise is actually coming from the the end of the door window where it meets the quarter window for the rear. It just started happening about a month ago. Tried cleaning the area...bending the rubbers around. Nothing seems to work. The car is pretty quiet under 60 but when traveling at around 65+mph it starts to make this whistle noise. Anyone got a suggestion other than to take it in for service?
Thanks guys.
~PeaceOut
Old 01-13-2008, 02:53 AM   #6
BMWBig6
BMWBig6's Avatar
Default Yes a button back there would be nice...
I just read in the manual that Audi deliberately didn't offer a latch release button on the outside of the car as a safety measure when the car was parked/idling while unlocked (I think the manual even mentions a stoplight scenario where your valuables in the trunk could be vulnerable?).
I'll have to check the wind noise over 65. It was fine below 60 last night when I remembered to listen carefully.
Ben
Old 01-13-2008, 11:27 PM   #7
PeaceOuTT
Default Humm...your scenario seems valid.
Wonder what the other companies do about it.
About the wind noise. Mine probably has a problem...because it wasn't like this before. It just started happening about a month ago. Thanks for the help.
~PeaceOut
Old 01-14-2008, 02:15 PM   #8
kimochi
Default same noise here: Re: Trunk latch noise? Wind noise when going 60+mph
I have the same noise coming from the same area as you mentioned. it only happens to the driver side. I've taken the car to two dealers. They have adjusted the dorr striker, window, & replaced the seals...... nothing works.
kimochi is offline   Reply With Quote
Old 01-15-2008, 10:16 AM   #9
PeaceOuTT
Default That's bad news.
It's this whistling noise at 65+mph. I've read that playing with the rubber seals (pulling them towards you and running your finger along the seal...they called it "fingering"...haha) has helped some of the UK people with this problem.
Strangely enough it's only on the left side of the car.
Hope this helps...I guess I'll go try again since the dealer doesn't seem to be able to fix it.
~PeaceOut
audi, audii, noise, tt, wind
