Battery location?
Old 09-06-2008, 01:09 AM
Jack Lai's Avatar
Default Battery location?
Can someone please tell me where is the battery located on 3.6 Q7 (US Version)?
The manual says it is under the driver seat but I can't see anything there.
Thanks for your help!
EDIT: Well, after taking a 2nd look, it appears that the battery is there, BUT how do I get to it? Do I have to remove the entire seat? If so, does anyone have more info on it? Thanks
Old 09-06-2008, 01:41 AM
Jusforfun's Avatar
Access is from the outside. Terminals are under the hood. No service
Old 09-06-2008, 08:02 AM
MarkItZero's Avatar
Default Why do you need to get to it?
If it is a jump start or the like use the terminals under the hood for that. The battery requires no maintenance.
Old 09-06-2008, 09:07 AM
mksap11's Avatar
if you *really* need to get to the actual battery, then yes, you need to remove the entire seat
Old 09-06-2008, 02:33 PM
v6tdi's Avatar
Default its under the drive's seat. you only need to remove the front bolts of the
seat. its under a charcoal filter that you have to unclamp inorder to get to the battery.
Old 09-06-2008, 05:40 PM
mksap11's Avatar
good to know. the factory repair manual tells you to remove the entire front seat
pagpc
Q7 MK 1 Discussion
10-21-2023 09:09 AM
nebalt
Q7 MK 1 Discussion
20
03-20-2018 04:47 PM
mtnxtreme
Q7 MK 1 Discussion
12-16-2013 07:15 AM
4RINGSx3
Audi Original "S" Cars
09-06-2012 08:38 AM
Quick Reply: Battery location?
