How do I replace the headlight bulbs?
Old 06-19-2007, 07:49 PM
Kewl7Newbie's Avatar
Default How do I replace the headlight bulbs?
I just bought a 3.6 Q7 with the Halogen headlights and want to replace the bulbs with something brighter. Strangely, the owner's manual doesn't have instructions on this. Can someone please give me a step-by-step on how to do this? I opened the hood and it looks like engine components are blocking access to the back of the light casing. Help!
Old 06-19-2007, 08:35 PM
MarkItZero's Avatar
Default "Strangely, the owner's manual doesn't have instructions on this"
have you noticed the large plastic pieces covering the engine compartment? Audi doesn't want you working on the Q7... even the bulbs.
Old 06-20-2007, 04:34 AM
mksap11's Avatar
There should be 2 releases - one on the inside and one on top. I'll see if I can't dig up a picture
Old 06-20-2007, 06:26 PM
mksap11's Avatar
Default Here are some pics on removing the headlight housing (to get to the bulbs)
This picture shows you the two releases on the headlight housing. You'll need to pull up on the left one and push down on the right one.
<img src="http://i165.photobucket.com/albums/u55/mksap11/Q7/IMG_1042.jpg" alt="Photobucket - Video and Image Hosting">
1) Pull up on this release (it requires a modicum of force to get up)
<img src="http://i165.photobucket.com/albums/u55/mksap11/Q7/IMG_1043.jpg" alt="Photobucket - Video and Image Hosting">
2) Disconnect the electrical harness just aft of the release
3) While pushing the headlight housing towards the front of the car, push down on this latch to release the headlight
<img src="http://i165.photobucket.com/albums/u55/mksap11/Q7/IMG_1044.jpg" alt="Photobucket - Video and Image Hosting">
Old 06-20-2007, 07:13 PM
Default Re: Here are some pics on removing the headlight housing (to get to the bulbs)
Thanks for the great instructions mksap11. Audi should hire you to write their Q7 owner's manual!
Old 07-21-2007, 06:35 PM
fwyt's Avatar
how do u do step 2?
2. Disconnect the electrical harness just aft of the release
There seem to be something holding it on, can't release it.
Old 08-02-2009, 04:03 PM
Niketalk1's Avatar
do those two releases in the pic release the large plastic piece at the back of the headlight or does that just allow you to release the housing?
Old 08-03-2009, 01:42 PM
Railflyer's Avatar
It allows the headlamp unit to come out the front of the grill. You then just open the acess ports and change the bulbs. After finding this thread I changed all 4 bulbs in 10 minutes.
Just be careful on install the top of the headlight has to slide into a T shape track.
Old 08-03-2009, 05:57 PM
Niketalk1's Avatar
So I don't have to take off the 4 screws holding down the headlamp unit...is that correct?
Old 08-04-2009, 09:03 AM
Railflyer's Avatar
You are correct, just pull up that tab that is in the inner part of the head;lamp housing and then push down the tab that is on the outside of the assembly then push out the front of the car. Those screws hold the lamp assembly mount. The headlamp just slides into that mount.
Quick Reply: How do I replace the headlight bulbs?
