Just ordered a VAGCOM
Old 01-26-2007, 03:08 PM
MarkItZero's Avatar
Default Just ordered a VAGCOM
any codes out there to turn off chimes and such like you can do in the Touareg?
Old 01-26-2007, 03:10 PM
K2audi's Avatar
Default I'm hoping for the same info. I'm hoping I can connect with my VAG-COM and do a little
customizing when our Q7 arrives ;-)
Old 01-26-2007, 03:25 PM
mksap11's Avatar
Default Windows Up/Down with remote
Module 46
Enable Comfort: Add 128 to existing coding
Adaptation (10) Channel 61: Add 5 to existing coding.
<a href="http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Comfort_System">http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Comfort_System
</a>
0000001 = Reserved (always)
0000002 = 10 Tamper Alarms (PR-B09)
0000004 = Thatcham inactive (PR-7AA/A8U)
0000008 = Selective Central Locking (PR-4K2/4K7/4K8)
0000016 = Anti-Theft Warning System (PR-7AN/7AL)
0000032 = Inclination Sensor installed (PR-7AN/7AL)
0000064 = Interior Monitoring (PR-7AL)
0000128 = Comfort Function via Remote (NOT PR-B29/B30/B34/B35)
0002048 = Confirmation Anti-Theft System via Horn (PR-A8U)
0004096 = SAE Rear Lights (PR-A8U)
0008192 = Light Package (PR-QQ1)
0016384 = SAFE-Function deactivated (PR-A8U)
0065536 = No Anti-Theft Delay (0 Seconds)
0262144 = Sunroof / Open Sky System (PR-3FU)
1048576 = Luggage Compartment Closing Assistance (PR-4E7/4E9)
2097152 = Rear Lid Control Module (PR-4E7/4E9)
4194304 = Fuel Lid Unlock via Driver Door Button
Note: Coding is the sum of the individual options. Not all options apply for all control moduls!
Adaptation Channel 061:
Changed to: 15 (+1 and +4 = windows closing via Remote Control)
Channel 061: Comfort Functions
+001 = Comfort Closing: Window Regulators via Remote Control
+002 = Comfort Opening: Window Regulators via Remote Control
+004 = Comfort Closing: Sunroof via Remote Control
+008 = Comfort Opening: Sunroof via Remote Control
+016 = Comfort Closing: Window Regulator via Switch Drivers Door
+032 = Comfort Opening: Window Regulator via Switch Drivers Door
+064 = Comfort Closing: Sunroof via Switch Drivers Door
+128 = Comfort Opening: Sunroof via Switch Drivers Door
+256 = Comfort Closing: Window Regulators via Lock Cylinder
+512 = Comfort Closing: Sunroof via Lock Cylinder
Note: Adaptation value is the sum of the individual options.
Old 01-26-2007, 03:31 PM
mksap11's Avatar
Default Seatbelt Chime disable
Module 17 (Instrument Cluster)
Default Coding: 2641263
New Coding: 2641203
NOTE: Your coding may be different than mine. I used the following coding guidelines to change the next to last digit from "6" to "0"
<a href="http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Instrument_Cluster">http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Instrument_Cluster</a>
????xxx: Options
+0001 = Quattro (Standard)
+0002 = w/o Driver Information System (DIS)
+0004 = Vehicle with Clutch (NO Automatic)
+0008 = Second Tire Size Pair
+0016 = Tire Pressure Monitoring
+0032 = Adaptive Air Suspension
+0064 = Advanced Frontlighting System (AFS)
+0128 = Adaptive Cruse Control (ACC)
+0512 = Vehicle w/o Electronic Parking Brake (Standard)
+2048 = Switch Option for Bord Computer Levels
xxxx?xx: Country
0 = Germany
1 = Rest of World (Left-Hand-Drive)
2 = USA
3 = Canada
4 = Great Britain
5 = Japan (Left-Hand-Drive)
6 = Arabian States
7 = Australia
8 = Rest of World (Right-Hand-Drive)
9 = Japan (Right-Hand-Drive)
xxxxx?x: Seatbelt Warning
0 = No Seatbelt Warning
1 = Seatbelt Warning (EU-NCAP)
2 = Seatbelt Warning (NAR Old)
3 = Seatbelt Warning (NAR New)
4 = Seatbelt Warning (EU-NCAP incl. Passenger)
5 = Seatbelt warning (NAR Old incl. Passenger)
6 = Seatbelt Warning (NAR New incl. Passenger)
xxxxxx?: Illumination
0 = Needles OFF and Scales OFF (Term. 15 ON / Term. 58 OFF)
1 = Needles ON and Scales OFF (Term. 15 ON / Term. 58 OFF)
2 = Needles OFF and Scales ON (Term. 15 ON / Term. 58 OFF)
3 = Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF)
bg_2007Q7 (05-09-2022)
Old 01-26-2007, 04:53 PM
MarkItZero's Avatar
Default I'm curious about channel 050 (adapative brake lights)
I wonder if it can be enabled on US models.<ul><li><a href="http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Comfort_System">http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Comfort_System</a></li></ul>
Old 01-26-2007, 04:55 PM
MarkItZero's Avatar
thanks, that's what I need
Old 01-26-2007, 08:43 PM
merc_320's Avatar
Default MarkItZero
Where did you buy your VAGCOM?
How much are they going for?
Old 01-27-2007, 07:38 AM
MarkItZero's Avatar
Default Ross Tech..
$349. You need a laptop computer to use with it.<ul><li><a href="http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=PROD&amp;Product_Code=VCHUC&am p;Category_Code=VAGCOM">VAG-COM License with HEX-USB+CAN Interface</a></li></ul>
Old 01-27-2007, 01:49 PM
V10_MAN's Avatar
Ordered mine just now
Old 01-27-2007, 05:32 PM
mksap11's Avatar
Hmm. Interesting. But what does it do, exactly? Can't find any Audi specific info on Google or AW
Quick Reply: Just ordered a VAGCOM
