Go Back   AudiWorld Forums » Technical Discussion » Motors » 2.0T FSI Discussion
Old 06-04-2007, 05:54 AM   #1
Chef S.
Senior Member
Default Fuel System Cleaning in the 2.0T (Product Reco Needed)
My wifes car has some built up deposits on the fuel injectors/carborator etc....forcing the car to take an extra second to turn over after turning the key in the ignition.No issues in performance or drivability. Parts do not need to be replaced, just cleaned per the dealer. Hence, not a warrenty item. Dealer wants 280.00 for the cleaning, they will flush the system with some substance 10X stronger then gasoline to clean it.
I wanted to take a crack at trying to use some additives etc myself before just allowing the dealer to....
Any ideas on best products to use? Of course there is your normal bottles of STP Fuel Carborator cleaner that one can add to a tank of fuel but who knows if that will work. Short of adding a few bottles of that when the tank of fuel is very low so a very rich mixture to work on these deposits, are there any other products out there to try or consider before I just give it to the dealer? Thanks.
Chef S. is offline   Reply With Quote
Old 06-04-2007, 07:26 AM   #2
pierranchis
Default race gas!
high octane gas i known to clean out the injectors and such, i live in fl, so the 110 octane UNLEADED down here is like 7.50 a gallon..dont know where you live and how gas prices are but if pay 3.30-50 per 93 octane then theres your average price..thats supposed clean it out pretty nice and also give a good pep to ride ..
pierranchis is offline   Reply With Quote
Old 06-06-2007, 05:29 AM   #3
pierranchis
Default made a slight mistake...
my bad, i got confused with the octane...110 is LEADED...go with 103..sh*t happens!
Old 06-08-2007, 02:14 PM   #4
Kayaker
Default Check this link
This guy doubts you have fouled injectors in such a new car. Are you using a very cheap brand of gas? I agree with his point that if you use any fuel sytem cleaner, do it just before an oil change. The solvents and deposists it cleans will end up in your oil and could significantly change viscosity and other characterics that could harm your engine.
The link is from a post on octane over in the A3 forum
Kayaker is offline   Reply With Quote
