Go Back   AudiWorld Forums » Technical Discussion » Motors » Inline-5 Discussion
Old 03-09-2005, 07:12 AM   #1
Katman
Default urq/MC1 Flywheel Timing Pin location?
Ok... So I have a I5 turbo flywheel sitting on the bench.
How can I tell if it's from a urq or a MC motor?
(Something like "The pin is XX teeth away from the TDC 0 mark" ?)
As far as I understand, the flywheels are the same except for the location of the timing pin. However, as timing is controlled by the ECU (relative to the pin), adjusting any error introduced by the wrong pin location is not possible.. Not as simple as giving the distributor a crank of a few degrees!
Or related: *IF* I do have a urq flywheel, what happens if I use it on a MC motor & ecu, in terms of spark timing?
Thanks...!
-Frank-
"The Twins"
www.frankdekat.com
CGT/4K Frapper map
Plenty Many Audi Pictures!
Katman is offline   Reply With Quote
Old 03-09-2005, 07:23 AM   #2
urq20vt
Default MC (and all newer I5s) 62 degrees BTDC, WX 60
urq20vt is offline   Reply With Quote
Old 03-09-2005, 07:42 AM   #3
Katman
Default Re: MC (and all newer I5s) 62 degrees BTDC, WX 60
So.. Even If I have a WS flywheel on a MC motor, all I'll be doing is running 2deg retarded everywhere. Doesn't sound like a big problem.
But how can I tell what one I have, looking at the flywheel itself?
Regards,
-Frank-
"The Twins"
www.frankdekat.com
CGT/4K Frapper map
20t, audi, fly, flywheel, locator, pin, timing, wheel
HTML code is Off
