#11 | ||
#12 |
I have the Euro manual.....will have to look at it some more.
#13 |
Code letters: BAS
Displacement, Liters: 4.163 Output, kW @ RPM: 221/6200 Torque, Nm @ RPM: 380/2600-4700 Bore dia., mm: 84.5 Stroke, mm: 92.8 Compression ratio: 11.0 RON: 98 Injection/ignition system: Bosch Motronic Ignition sequence: 1-5-4-8-6-3-7-2 Knock sensor control: Yes Exhaust Gas Recirculation (EGR): No Intake manifold change-over: Yes Camshaft adjustment: Yes Secondary air system: Yes Valve timing ----------- Intake valve opens after TDC: 42 Intake valve closes after TDC: 62 Exhaust valve opens before BDC: 40 Exhaust valve closes before BDC: 10 |
#14 |
Mods: And old out-dated trademark slogan for a license plate. |
#15 |
"camshafts with greater lift AND modified timing ensure optimum cylinder filling, with the inlet valve timing matched to the engine's relevant operating point by a hydraulic camshaft actuater"
#16 |
Hi,
I'm from Poland, to first time in this forum. I drive audi S6 C5 40V ANK-motor and I'm looking for data for my car like this, that I found, but they are not for my ANK engine. This data comes from Bentley Official Factory Repair Manual: AYS Camshafts (S8 V8 4.2 40v) Intake open after TDC 25º Intake close after BDC 45º Exhaust open before BDC 38º Exhaust close before TDC 8º Do you have and can check this data for my ANK- motor pleas? I can't find it at all and I don't have this Bentley Book .My engine is allredy by mechanic, who trys to set up it. Thanks in advance! Marcin |
| Tags |
| 2003, 2453520, 32, 42, a5, a6, abz, aimtahc, air, audi, bore, cold, emission, euro, intake, pirelli, rs6, standard, tdc |
