Go Back   AudiWorld Forums » Technical Discussion » Motors » 1.8T Discussion
Old 10-29-2008, 11:02 AM   #1
richmt
Default No start, no spark, no good
Hey, drove my 2000 1.8T (ATW)home after a four hour trip - noticed the clutch was beginning to go. While I had the car apart to change the clutch, I changed the timing belt, water pump, plugs, oil, etc. Anywho...the car will not start, not even turn over. The dash lights up, now the EPC light is on with the strangest beeping noise. Checked the fuses and wiring, but I am at a loss for what to do next, any suggestions?
richmt is offline   Reply With Quote
Old 10-29-2008, 07:55 PM   #2
Melinko bq
Default Doesn't turn over? As in... doesn't crank / starter doesn't turn?
My guess is to check the starter. Perhaps you forgot a wire down there or mixed up when reinstalling clutch.
If it does turn, but doesn't fire plugs, that's a different issue. But... you said, 'No start, no spark'... so is it cranking / trying to start at all?
Melinko bq is offline   Reply With Quote
Old 10-30-2008, 06:51 AM   #3
A3dubbs
Default Check timing on cam shaft.
Sometimes with doing timing on the car if u turn the motor the wrong way the cams jump timing..
A3dubbs is offline   Reply With Quote
Old 11-03-2008, 02:04 AM   #4
richmt
Default FIXED, IGNITION SWITCH BAD!!!
Problem fixed....ignition switch was bad. Runs like a charm now. Thanks for the input.
Old 11-04-2008, 06:52 PM   #5
Melinko bq
Default Glad to hear!
100, 1991, 20, 200, 2000, 80, a4, audi, belt, crank, ignition, jumped, quattro, replace, spark, start, switch, timing
