Go Back   AudiWorld Forums » Technical Discussion » Motors » 1.8T Discussion
Old 05-25-2008, 04:36 AM   #1
hockeypuck
Default 1.8 t oil pressure questions-vag codes
I understand and have read muchos postos on the dreaded oil sludge issues with the 1.8t. I am looking at a a4 and passat today and was wondering if there is a specific code that will be stored when I dump the vag codes?
hockeypuck is offline   Reply With Quote
Old 05-25-2008, 05:07 AM   #2
JAFO
Member
Default not that i know of. best way to check for sludge is to remove valve cover
'97 1.8tqms A4: apr stage 1, Miltek exhaust, K&N, SB/OFE clutch, S4 liner, apr snubby, bilstien hd, , h-sports arb's,cpp rear down links, autospeed dts, racetec strut brace, ecs 2 pc. A8 front brakes,pbr/axxis deluxe pads, goodridge ss. brakelines suspension hardware , sports mats, sunglass holder,
JAFO is offline   Reply With Quote
Old 05-26-2008, 04:42 PM   #3
FLACO X3
FLACO X3's Avatar
Default ^^^2nd that...
I bought my car w/ sludge. To help prevent it change your oil regularly and use a big *** filter. Even opening the oil cap, you can see sludge build up on the camshaft.
2000 S4: Borla Catback, H&R Coilovers, 034 Bi-Pipes, JHM boost gauge, Bailey DV's.
STAGE 2 2001.5 A4 1.8TQA... RIP
www.racersweb.com
www.leftlanelife.com
FLACO X3 is offline   Reply With Quote
Old 05-27-2008, 08:58 AM   #4
Bryancald
Default Re: 1.8 t oil pressure questions-vag codes
Don't forget about the other engine killer - debris on the oil pickup screen. You must drop the oil pan to get to this.
It's what did mine in, same symptoms as sludge. I had ZERO sludge using Mobil 1 oil.
Bryancald is offline   Reply With Quote
18t, check, hockey, light, oil, press, pressure, puck, vag
