Go Back   AudiWorld Forums > Technical Discussion > Motors > 1.8T Discussion
Old 01-17-2008, 10:10 AM   #1
HorschAudiA4
Account #: 91107
Default Coil Pack Keeps Going Bad
I have had a coil pack "go bad" three times within 4 months and 6,000 miles, on my 2004 A4 1.8T. This started happening right after the 35,000 mile service (which included a tune up). The dealer just shrugs it off ("These things happen."). I'm wondering if this might be a sign of a more serious problem with the engine (which the dealer might be trying to ignore, while the car is still under warranty). I would appreciate any advice.
HorschAudiA4 is offline   Reply With Quote
Old 01-17-2008, 10:17 AM   #2
Scenic Driver
Account #: 109968
Default Did they replace the spark plugs during the service?
If so maybe they are misgapped. Spark plug issues can cause misfires like a bad coil. I doubt it's a coincidence that this problem didn't exist before they touched the car.
__________________________________________________ __________________________________________________
ACNA quattro de Mayo 2007 (Alcoa,TN), 2008 (Highlands,NC)
TT-East 2007 (Charleston,SC), 2008 (Snowshoe,WV)
ACNA Shenandoah Fall Foliage Charity Fun Run 2007, 2008
Organizer, TT Bear Mountain Drive 2007, 2008
Organizer, TT Fall Foliage Drive 2008 (Catskills/Shawangunk Mtns)
Author, AudiWorld Event Coverage, TT-East 2008
"It's not the destination, it's the journey" - Road Trip & Event Pics
- "Only Two Things Are Infinite, The Universe & Human Stupidity, & I'm Not Sure About The Former" - Albert Einstein
- "Common sense, if it's so common why do so few people have it"
- "The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?"
Scenic Driver is offline   Reply With Quote
Old 01-17-2008, 10:21 AM   #3
HorschAudiA4
Account #: 91107
Default Re: Did they replace the spark plugs during the service?
yes, got new spark plugs with 35K service
Old 01-17-2008, 12:17 PM   #4
Scenic Driver
Account #: 109968
Default ...
I would replace the spark plug in the problem cylinder and also inspect the coil pack wiring harness.
Also I would consider different dealer if that is an option.
Old 01-20-2008, 01:29 PM   #5
ll euroa4 ll
Account #: 123013
Default valve cover gasket may be leaking
ll euroa4 ll is offline   Reply With Quote
Old 01-21-2008, 07:02 PM   #6
warrantysucks
Account #: 140253
the audi plugs come gapped. you don't need to gap them. It's possily that the insulation on the plug is cracked. try swapping the plug to another cylinder and see if the problem follows the plug. On the other hand, coils going out is a very very common problem and in no way indicates any other damage or issues.
warrantysucks is offline   Reply With Quote
Old 01-22-2008, 10:32 AM   #7
Gordan T.
Account #: 2193
Default Can you please elaborate?
How would this cause coil pack failure?
Thanks...
Gordan T. is offline   Reply With Quote
Old 08-18-2008, 05:13 PM   #8
attroquay
Account #: 119468
I'm adding to an old thread, but I just finished replacing a coil pack on my 02 A4-1.8T.
Engine lost power and limped along, threw a flashing CEL.
I hooked up the VAG COM and found a code for misfire on cylinder 1. I swapped the coil packs on cylinders 1 and 2 and restarted it. Now I got a misfire code from cylinder 2. Just to be sure, I swapped the coil packs on 2 and 3. Restarted and got the misfire code on cylinder 3.
Luckily carousel audi has a parts dept that is open til 9pm. Picked up two coil packs ($38 each) and replaced the bad one on cylinder 3.
Started up and drove home with no problems.
BUT....
I just changed the plugs yesterday and I wonder if there is any way that the plug service could have caused the coil to go bad. I did not change the gap (stock NGK's but not from dealer).
By the way, all four coil packs were Rev. J. The new ones from the dealer are Rev. R.
attroquay is offline   Reply With Quote
18t, 2004, 30, a3, a4, audi, bad, coil, coilpacks, cyclinder, cylinder, installing, pack, packs, plugs, spark
Forum Jump
