Go Back   AudiWorld Forums » Technical Discussion » Motors » 1.8T Discussion
Old 08-22-2005, 04:49 PM   #1
Laughing Gnome
Member
Default maf data logging question.....updated
did some 3500 to redline logs to se if my maf was on its way out and the readings i got were a maximum of 132g/s at 4900rpm. Is this a sign that my maf is dying? replaced the maf and this this runs like new, man what a difference it made.
Laughing Gnome is offline   Reply With Quote
Old 08-23-2005, 04:05 AM   #2
Ray Khan
Send a message via AIM to Ray Khan
Default peak should be a number about 80% of your horsepower
so if your car is a stock 1.8T then that sounds ok.
Ray Khan
00 1.8T QM
APR stage 3+
APR Exhaust
APR Intake
DUH FMIC
Southbend OFE Stage 4 clutch
SPEC 12 lb flywheel
Greddy Profec B electronic boost controller
Porshe Boxster calipers
BIRA stage I brackets
Hawk HPS brake pads
A8 rotors, SS lines
V&S Short Shifter
Vogtland Coilovers
Neuspeed 19mm rear sway
18x8 Flik Lex
235/40/18 Falken GRB 451
17x7.5 B5 S4 Avus
205/50/17 Dunlop Wintersport 3D
Sony XM 7554 amp with 5.25" and 6.5" Infinity kappas
MTX 801D amp with 2x10" kenwood sub enclosure
Xenons
Fog light relay mod
VDO boost gauge in custom vent pod
Clear corner mod
S4 wheel well liner
RS-4 grill
AIM and MSN messenger:rakha77
Ray Khan is offline   Reply With Quote
Old 08-23-2005, 01:28 PM   #3
AvantMnkyA4
Member
Default seems kind of low. My TT 180 get 150 around that RPM
03' Black A4 Avant Quattro
Tiptronic/Sport suspension/S4 Sway/18" OZ Superleggera
B5S4 Brakes/Hawk HPS/Stoptech SS Lines
Tint: 20% rear / 35% front
AvantMnkyA4 is offline   Reply With Quote
Old 08-24-2005, 03:40 PM   #4
A400
A400's Avatar
Default Please tell me where I can find that info Ray, always willing to learn.
Whole lotta car
A400 is offline   Reply With Quote
Old 08-24-2005, 06:44 PM   #5
Ray Khan
Default from some Ross-Tech/VAG COM notes on MAF testing
a friend had it for when we tested her MAF and the numbers worked out right for a stock turbo car. I know if you convert turbo flow to g/s it should work out pretty closely.
Ray Khan
00 1.8T QM
APR stage 3+
APR Exhaust
APR Intake
DUH FMIC
SPEC 12 lb flywheel
Hawk HPS brake pads
A8 rotors, SS lines
V&S Short Shifter
Vogtland Coilovers
18x8 Flik Lex
17x7.5 B5 S4 Avus
Xenons
Fog light relay mod
Clear corner mod
S4 wheel well liner
RS-4 grill
Old 08-24-2005, 08:49 PM   #6
Yippers®
Member
Yippers®'s Avatar
Default Here's a post from Uwe .. I've read this elsewhere as well.
Yippers® is offline   Reply With Quote
Old 08-26-2005, 10:37 AM   #7
A400
A400's Avatar
Default So mine should show 440? I will try this and see. I have dyno figs so that is what it should show.
Whole lotta car
Old 08-26-2005, 11:23 AM   #8
Yippers®
Member
Yippers®'s Avatar
Default For ~550 crank .. yes ~440g/s. This presumes there isn't a scaling work-around in the system.
For example, on the nDBW Stage III APR uses the OE MAF housing and MAS. They add a divider circuit to the chip and keep the OE 'map scaling'. So I see maximum MAF readings of around 230g/s on the 93 program. 230/.80=287
On the otherhand, PES/GIAC chose to work around the (~5v) OE MAF voltage limit by using a larger MAF housing with the OE MAS centered in the wider portion of the MAF housing barrel. Given they know the amount of flow that 'escapes detection' they scale the fuel delivery accordingly. As a result working around the voltage limit this way, the OE scale is in effect and PES cars will only read ~170g/s as the other ~50-60 g/s goes 'around' the MAS.
So, depending on exactly how Hans approaches the set up in your situation, the 'rule' may or may not hold for you.
Old 08-29-2005, 01:05 PM   #9
Audi2ptzero
Elder Member
Default I thought you would be running mafless?
The maf readings only work if your running a stock maf sensor/housing combo. Once you change that the readings and scale rate will change.
Audi2ptzero is offline   Reply With Quote
Old 08-29-2005, 01:09 PM   #10
Audi2ptzero
Elder Member
Default On my custom setup he also rescaled the maf readings to work with my 3.5" housing and stock sensor.
This gives me a standard 5-6g/s reading at idle and a reading of 230-250 g/s when producing 400+ whp. Only bad part is that the DBW maf doesn't work like the ndbw, there is no 0-5 volt signal for me to see what % it is running at.
