#1 | ||
04 B6S4 - JHM Beast w/ good driver mod. |
#2 |
Elder Member
#3 |
since boosting in winter would be 14-15psi and summer could have the potential to be 24psi. I am currently at 21psi in the summer. I know the winter air is denser than summer...do you foresee it being an issue...or really the same difference?
#4 |
Elder Member
Problem might be in that the adv timing will be too high for 24psi unless you feel like running higher octane. Also have to watch out for the IAT's since they will also increase with more boost.
#5 |
#6 |
Elder Member
That will get higher as you increase the boost level.
#7 |
than 93 octane.
#8 |
Elder Member
which means you can check block 026 during wot and see how high the voltage gets. Max is around 26 so if your near that right now with the setup you have then you will need higher octane if you push the boost even higher.
#9 |
