| A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5 |
#1 | ||
06 2.0T Sline Black/Black Fully damn loaded |
#2 |
I plan on having the dealer fix it when I take the car in for 5K service. Policy used to be that dealer would correct one time at N/C.
#3 |
I took it to the dealer at around 100 miles and they said it was fine. I just don't have the time or the patience to go through all that waiting again.
#4 |
Have the dealer realign the car, making sure that the steering wheel is properly positioned.
I had the same problem, except mine pulled to the right. The first dealer couldn't figure it out, but a second one did after I pointed out the problem was with the steering wheel, not the toe, camber, etc. |
#5 |
Junior Member
THe steering wheel centering is a seperate adj. and should be fixed. If the alignment is correct it won't cause abnormal tier wear, but it takes away from the driving enjoyment. Bring it back.
#6 |
I'm gonna give it one more try..This time with another audi service station..thanks guys...i'll keep you posted
#7 |
When aligning the car, the tech has to be careful to make certain that the steering wheel is in the proper position while aligning the car, as jim'02a4 eludes to.
The rest of the alignment may actually be OK, but adjusting it to match the steering wheel will likely require them to do the whole thing over again. They can't just tweak the steering wheel, because the alignment has to be done while the steering wheel is in the appropriate position. |
#8 |
I've had this problem at one time or another with three different cars; Saab 9-3, Toyota Corolla and Toyota Camry. Jim'02a4 is absolutely correct. Also, steering wheel off center is the most common reason that people return their cars to shops for re-do's after alignment jobs.
Don't put up with it, because it will aggravate you and it has a simple fix. Regards, Mooselook
#9 |
Member
If that's the case, the wheels would have to be held slightly to the left to go straight.
Also, check tire pressures. One tire being a little lower will cause a little bit of pull.
Minnesota Audi Club 2001.5 Audi A4 1.8TQMS APR Stage 3+, APR Exhaust, Eibach Pro Street Coilovers, Neuspeed 19mm rear sway. |
#10 |
Roads are usually cambered to be slightly higher in the center, so a properly aligned car may sometimes pull right. But Nick's is pulling left, so that's probably not it in this case.
Good idea about checking tire pressures, though, I forgot to mention that. |
| Tags |
| 2000, a4, audi, b5, camry, center, centre, fix, steering, toyota, wheel |
