How exactly do you pack a CV joint with grease? (edit)
Old 05-17-2004, 11:07 AM
Member
Shep 1.8T's Avatar
Default How exactly do you pack a CV joint with grease? (edit)
also can I pack it and then run it on the shaft, or do I have to do it almost simotaneously?
Old 05-17-2004, 11:10 AM
HOPSBurner's Avatar
Buy papers?
Old 05-17-2004, 11:11 AM
mdcbuym's Avatar
Default what exactly are you asking?
How to take it apart or pack it with grease?
Old 05-17-2004, 11:17 AM
EuroTrashA4's Avatar
Default it's easy
All you need to do is use the supplied grease that comes with the new boot and once you attach the small side go ahead and fill the boot with grease. You can also put some on the all the inerparts. Make sure before you do this step you have cleaned all the old grease and dirt out of it well. It is not "packed" like bearings where you can use a gbearing packer or do it the old fashioned way and get your hands dirty.
Old 05-17-2004, 11:20 AM
Member
Shep 1.8T's Avatar
Default pack it with grease
basically I have a bad CV joint, and I have the replacement sitting in my room with a boot, and a bunch of grease, and I am not sure exactly how to pack it.
Old 05-17-2004, 11:26 AM
Member
Shep 1.8T's Avatar
Default the joint is brand new.
so just pack it into the boot and all the parts, and then attatch?
Old 05-17-2004, 11:27 AM
Default Re: the joint is brand new.
yes that's all.
Old 05-17-2004, 11:32 AM
mdcbuym's Avatar
Default just put in the grease and spread it around with your finger
then put the rest in the boot. It will spred by itserlf when you drive it.
Old 05-17-2004, 03:51 PM
chaplin's Avatar
Default I'd use some rubber gloves. That grease will be messy.
Make sure you squeeze the excess air out of the boot, before clamping down, to prolong the life of the boot.
Old 05-17-2004, 04:08 PM
David.Norton's Avatar
Default If the joint came dry push it into the cup until no more will go...
don't just spread it around in the boot, it will just stay there. You need to get it down into the ***** that do the work.
jhoeppel
TT (Mk1) Discussion
04-13-2008 02:38 PM
gietl
Audi Original "S" Cars
02-20-2008 08:50 AM
rowdyzombie
TT (Mk1) Discussion
11-15-2007 09:07 AM
Quick Reply: How exactly do you pack a CV joint with grease? (edit)
