| A8 / S8 (D3 Platform) Discussion Discussion forum for the D3 Audi A8 produced from 2003-2010 and Audi S8 produced from 2006-2010 |
#1 | ||
Current: 2008 BMW M5 SMG 2004 BMW X5 4.4i Former: 2005 Audi A8L 2005 Audi S4 2003 Porsche Carrera 2003 Audi A4 3.0 2002 Ford F250 1994 Mazda Mx-6 LS 1990 Mercedes 300 SEL |
#2 |
a flush to the blue zf fluid i noticed some bad slipping from 2-3 occasionally. I tend to use tiptronic ALOT. getting the whole tranny replaced sometime around 75K kilometres.
groaning noise appears normal...could be just the power steering pump, it does get kinda loud and embarrassing sometimes. you could have prevented discolouration with some good wax. 2 plus years and 60000KM and paint+trim with zaino still look awesome. Hope this helps. |
#3 |
I've had the problem with the rainbow effect on the trim. Porsche has a trim cleaner which helps, but doesn't eliminate the problem. It goes away for a while, but comes back after a couple of car wash cycles.
In my case it wasn't on all the trim, just the pieces under the rear door window and around the C-pillar window on both sides. I was told that trim is not covered by warranty and the problem was caused by a car wash. I countered that it was clearly a defective trim piece, because all of my trim was going through the same car wash, and only those pieces were affected. After some grumbling, Audi agreed to replace the defective pieces as an "act of good will", not a warranty item. Hopefully, they'll stand behind yours as well.
Current: 2004 A8L (Black / Amaretto) 2010 Honda Odyssey (kids) 1980 VW Rabbit Convertible (1st car) Former: 2001 Chrysler Town and Country 2001 MB S500 AMG 2003 and 2006 Corvette Convertible 2004 and 2005 SSR 2002 Camaro Convertible 2001 Olds Bravada 1997 Audi A6 Avant 1989 Audi 200 Quattro 1987 Audi 5000 Turbo 1988 VW Jetta GLI |
#4 |
ran into similar issues on wifes new X5 running boards, also aluminum. fought with bmw reps and they blamed car wash.
remarkably, car wash agreed that rim cleaners can affect these finishes. i now avoid this option at the wash. used meguiars cleaner wax, seemed to work ok but will need redo every few months. no ill effects on the A8 though..
2007 A8L Northern/Tan/sport/prem 35% tints/kleen wheels/hardwired V1/2011 NAV installed heated mfsw w/paddles misc vagcom tweaks.. 07 bmw 335i cab 96 porsche 993 targa 11 linc mkx for the wife and a fistful of other german cars come and gone..
#5 |
levels were topped up eliminating the howl (so far!)
7 is caused by auto car wash systems. The pH of the wash system destroys the trim. The A/S8's all seem to withstand this much better than any other Audi model but they will all do it. I gave up on Auto car wash systems some years ago and suggest you do the same. The damage is chemical and no polish made will fix it. Audi will replace it. I had all Al trim replaced on an A6 and on an A4 Cabrio for the same issue. Good luck!
#6 |
happened to me...
the headlight washer fluid "robot arm" is leaking. Costs about $250 for the part...
