Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D3 Platform) Discussion
Old 09-16-2004, 07:57 AM   #1
gb4.2
Default 05 MMI Screen Fixed......here's a Nav question...
Almost one week has gone by and the new screen (pulled from an 04) in my 05 is working flawlessly. PaulW correctly termed the "repair" process as an "Easter egg hunt" but the end result was worth the hunt. The car is absolutely wonderful and now I can focus on everything else without worrying about the screen going black.
Here's an interesting question--does anyone know how to simply set the Nav system to show your movement on the screen's map display without having programmed a destination/route? The only thing close to this is setting the screen to show the current position. However, once you see the current position on the screen's map, the position is stationary even if the car is still moving--it only gives you a "snapshot" view and that's it. According to my service manager, he contacted NavTeq about this and they claim that Audi decided they didn't want its customers to be able to simply view their changing position on the map. They thought it would be "too distracting". If that's the case, why even bother installing a navigation system in the car???
gb4.2 is offline   Reply With Quote
Old 09-16-2004, 08:05 AM   #2
Mr. Ricco
Member
Default Re: 05 MMI Screen Fixed......here's a Nav question...
yes it is. . . .can't recall how I did it. . .you don't have to "set" anything. . . as I recall. . just hit the Nav switch and then play with the swithes around the Big Knob.
Mr. Ricco is offline   Reply With Quote
Old 09-16-2004, 09:44 AM   #3
D3AeighT
That is absolutly a BULL SH&^ statement your service manager made UNLESS they changed that for '05, which I can't imagine. Hit the NAV button on MMI then just push the button in the lower right quad(MAP button). This will give you a PIC that moves as you do. The D3 becomes a BLACK ARROW and moves with the postioning. You can change the Yards or Miles of closeness at it moves.
I'll never allow work on my MMI ( unless it goes belly up ) since I don't think I want any of these DOWNDATES ( get it UPdates )to the SW.
Normal Sig
Future Audi's:
DOUBTFUL!
Current:
2004 1/2 A8L VIN Mid 16000 to 16100
Atlas Grey Metallic-Sabre Interior-
19"OEM Wheels-12 Spoke
255-40ZR-19 XL Yoko ADVAN S.4 (Prev: Continental Sport Contact 2 ExLd (Good) & 2 sets of Pirelli Rosso OEM (POS's!)
SW:D3-HU 6346 06.0.0 0413(previous)
SW:D3-HU 33.6.0 0632 (May'07)
HW:D3-HU 6346 D2.0
FC SW:02332AUFC 78KOF46n
FC PS:0020 FC HW:H42
NAV VERSIONS: USA_0740_2093 DATA 288/20050217114407
'08 VW New Beetle (wife)
'02 Jeep Grand Cherokee (daughter)
'79 CJ5(SOLD IT FINALLY)
Prior Audi's:
'99 A8 4.2 Quattro - Black/Ecru
'97 A8 3.7 FWD - Black/Ecru
'92 100CS - Dark Green/Ecru
'87 5000 - Metallic Blue/Black
'85 5000 - Red / Black
AWP Sig
*WITH GUNS WE ARE CITIZENS, WITHOUT GUNS WE ARE SUBJECTS"
Clinton Admin After Jamie Gorelick "Wall" Memo
Battle cries of liberalism: "Our minds are made up - don't confuse us with the facts!"..."Liberals stand on their heads and tell the rest of the world it's upside down."
D3AeighT is offline   Reply With Quote
Old 09-16-2004, 09:47 AM   #4
AtlasD3Miami
Junior Member
Default Press nav....then map its the bottom right selection on the quad buttons.
AtlasD3Miami is offline   Reply With Quote
Old 09-16-2004, 09:52 AM   #5
gwelch
Default Your s.m. needs to rtfm...
My nav systems shows my progress. Just push the button for the Nav system, then push the button that corresponds with the map feature. (should be the lower right button next to the large dial.) Your car should show up on the map as a little arrow. Once the map is up you can change the zoom on the map by turning the dial. Hope this helps!
--Gina
gwelch is offline   Reply With Quote
Old 09-16-2004, 10:00 AM   #6
Sails_Guy
Not sure if something has changed with the 05 but in my 04 simply select NAV then MAP. It displays current position and tracks movement without route guidance active.
Sails_Guy is offline   Reply With Quote
Old 09-16-2004, 10:16 AM   #7
gb4.2
Default That's what I tried..doesn't work...
Thanks for the quick responses. I've done exactly what everyone's suggested in this forum so far but the result is still a "snapshot" of where the car was when I pressed the lower right button by the main MMI **** to get to "Map". There is no movement of the arrow (my car) on the map with the car in motion.
To make things more interesting, I called NavTeq in Chicago to check out this problem and confirm what my service manager told me....NavTeq says they only make the software (the DVD) and the Harmon-Becker makes the MMI system which controls what you see on the screen. My service manager's explanation does turn out to be B.S. The NavTeq guy gave me Harmon-Becker's toll free number which turns out to be Audi's Customer Relations' phone number!! (800-822-4236) I just left a message for my Audi Advocate (Mark) to call me on this.
Old 09-16-2004, 10:19 AM   #8
gb4.2
Thanks. My screen shows the car in a frozen position despite movement. See further response below under "That's what I tried..."
Old 09-16-2004, 11:26 AM   #9
AtlasD3Miami
Junior Member
Default *Hijack*...Sails you should insert your pic into your signature.
Old 09-16-2004, 11:51 AM   #10
greenie
Default WHAAAAAAAAAAT?????????? Who and where is your dealer?
_________________________________
greenie - serial #6625
greenie is offline   Reply With Quote
