Nail in tire - too close to edge for repair?
Old 05-21-2007, 05:26 PM
perlvater's Avatar
Default Nail in tire - too close to edge for repair?
Got a nail in my 245/40 R18 Conti Pro Contact tire almost exactly 1 " from the edge. I measure the width of the tire as ~9.25" and the nail is about 3.75 from center. (obviously "edge" is a bit rounded.)
I have received conflicting advice on being able to repair (plug) the hole. Anybody have any experience as to the minimum distance from the edge to put an effective and safe plug in the tire?
Old 05-21-2007, 05:42 PM
AudiWorld Uber User
April's Avatar
Default An inch is probably too close for a heavy car capable of some serious handling. BTW, I would
suggest a patch before a plug, for any number of reasons you can find online. But even then, it may be too close to the sidewall to help. Depends on the tire and the shape of the sidewall profile.
Old 05-21-2007, 06:53 PM
Egil A64.2s - S6's Avatar
Default I would guess that he does not use even 50% of the tire's load.
Most people just don't drive like you April ;-)
Old 05-21-2007, 06:54 PM
AudiWorld Uber User
April's Avatar
That may be true, but I don't presume;-)
Old 05-21-2007, 06:59 PM
NoVA_A6's Avatar
Default How many miles on the tire?
If you have more than 20K I would look to replace, otherwise you might be able to just plug it.
Old 05-21-2007, 11:44 PM
A6Gary's Avatar
Agree w/ April. BTW, most tire shops won't use a plug to repair a flat, only a patch on the inside.
Old 05-22-2007, 05:54 AM
perlvater's Avatar
Default Re: How many miles on the tire - 12k miles - ?
There are 12k miles on the tire and I was thinking of using it as a spare after repair. Sorry but i did not distinguish between an inside patch and a plug. I would expect the tire repair facility would select the better option.
Old 05-22-2007, 09:13 AM
AudiWorld Uber User
April's Avatar
Default Tire places often like the plug becuase they don't need to remove the wheel, and then the tire
to patch it from the inside. A plug shouldn't be more than $5 to $10 max. A patch is usually $20 to $25.
If you go with the plug route, make sure it's the self-vulcanizing type that uses the heat naturally generated by a rolling tire to melt into the tire.
The problem comes from a hole near the sidewall which is constantly flexing. That flexing could cause either plug or patch to work loose.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Ftires%2Ftiretech%2Ftechpage.jsp %3Ftechid%3D77">http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=77</a></li></ul>
Maybebuyaudi
Audi A5 / S5 / RS5 Coupe & Cabrio (B9)
9
05-27-2018 07:47 PM
wzy104
Wheels & Tires Discussion
12-26-2017 12:14 PM
Brad in FLA
Florida Discussion
12-05-2006 01:04 PM
PhilJ
08-21-2002 08:14 AM
got_root?
06-29-2001 11:09 AM
Quick Reply: Nail in tire - too close to edge for repair?
