Go Back   AudiWorld Forums » Audi Models » Audi A6 / S6 / RS 6 » RS 6 Discussion
RS 6 Discussion Discussion forum for the Audi RS 6
Old 04-03-2004, 05:37 PM   #1
Kreggin
Default Audi factory tire pressure monitor system
Ok, so I have this new RS6 and it supposedly has a tire pressure monitor....so how do you ( or do you ) "see" or display the pressures? Or does it just warn you ... I don't see anything in the owners manual that expalins any of this. Thanks !
Kreggin is offline   Reply With Quote
Old 04-03-2004, 06:47 PM   #2
Randy Welch
Member
Default US spec doesn't have the tire pressure monitoring system
European ones have it as an option I think.
-randy
03 RS6 Daytona/Silver/STaSIS Motorsport Suspension
And yes, my car returns the favor....
Randy Welch is offline   Reply With Quote
Old 04-03-2004, 07:43 PM   #3
Kreggin
Default Re: US spec doesn't have the tire pressure monitoring system
Thanks - that explains the mystery!
Old 04-03-2004, 09:51 PM   #4
avdh
Member
Default Right, but I seem to be loosing air, very slowly, because of those things. I have to refill on a
regular basis.
avdh is offline   Reply With Quote
Old 04-04-2004, 09:32 AM   #5
Randy Welch
Member
Default I wonder why?
It would strike me that the tire pressure sensor shouldn't cause a leak.
I wonder if my wife's A8L will have the same issue...
-randy
Old 04-18-2004, 04:23 AM   #6
TheBrit
Rest In Peace
Default What kind of air temps do you have over there?
Last summer I did start losing air through the TPM valve stems, but through autumn/winter/spring I've not noticed any appreciable loss. I wonder if there's a certain temperature point at which they lose air - different expansion/contraction rates of the different metal compound used?
Another thing to watch out for - don't replace the plastic valve caps with metal ones. I did (the shop lost the grey plastic ones and put standard black ones on and they looked awful) and now after a while they've become stuck on. My business partner's car went into the shop because he couldn't get them off and they broke one of the stems trying. Mine has two stuck which I expect will have the same problem when I need to get them off next. The metal compound seems to react badly with metal caps, which I now assume must be designed for standard brass/rubber stems.
I'm British - you probably won't understand.
ChrisB aka TheBrit, as named by Clout and SantorinSteve
S8 Review:3 weeks
Sig pic so badly outdated that it's been dropped
TheBrit is offline   Reply With Quote
Old 04-20-2004, 02:07 AM   #7
avdh
Member
Default Now that we are going onto winter, I have to refill less frequently,
in the middle of summer (January) we get 40 Degree C max (104 F)with 35 (95 F) average.
I use Nitrogen in my tyres.
As for the metal valve cap, I also use these, but have had no problem with them being stuck.
Old 04-20-2004, 06:56 AM   #8
TheBrit
Rest In Peace
Default I guess heat plays a part then. The metal caps seemed to have reacted to salt on the road
during winter, so it may not be an issue for you.
S8 Review:3 weeks
Old 04-20-2004, 09:09 AM   #9
avdh
Member
Default No salt on SA roads :)
audi, audis, factory, pressure, sensor, sig, tire, tpm
