#1 | ||
1993 Audi 90My Garage Join Date: Oct 2008
1993 Audi 90CS Quattro (loving it) *new front struts, 034 control arm bushings, tie rods. mount savers. B5 sport rear springs/socks, B5 sport swaybar, B5 upper a-arms, 034street density trans mounts,17" ASA, head lights, aux gauges. blue plasma instrument cluster, A4 3 spoke steering wheel, aluminum subframe mounts) *replaced a motor at the end of 2008, gasket matched heads, ARP head studs, air box velocity stack, 4 to 3 wire MAF conversion, 18.5lbs flywheel with SPEC stage 2 clutch. 1975 VW bus (gone) 1973 VW Super Beetle (what was i thinking?) 1968 VW Bug (my pride and joy) *2.5 inch front drop and disk brake conversion, *2110cc motor (in progress)new wiring harness,3 inch wider fenders all around, 195/45r15 front and 195/65r15 rear tiers 1991 GMC Sonoma RWD, manual, 4 banger (gone) 1979 Suzuki GS750EN with 31k original miles 1981 Suzuki GS750L (will be on a chopping block for a bobber) 1981 Yamaha XV920 1983 Yamaha XV750 (for g.f.) 1985 Dnepr MT10-36 (stolen) 1992 Dnepr MT11-32 (also stolen) |
#2 |
His AFC was out of his '97 A4 and has a fan on the drivers side that, IIRC, I can't have there. I need a diagram of the belt set up for my '94 90Q to install smoothly. I may just use my other AAH engines to look at.
| Tags |
| 1995, aah, afc, audi, audio, cabriolet, code, complaints, cylinder, head, heads, interchangable, replace, v6, work |
