Go Back   AudiWorld Forums » Technical Discussion » Motors » 12v V6 Discussion
Old 04-25-2008, 06:45 PM   #1
1995Qsport
Default Light throttle Hesistation/Miss?!
Ok i have a slight problem, while taking off going light throttle the car will hesistate and then pick up if you tap the gas a little more. When revving in neutral its a clearly audible miss-fire did the dark test and #6 wire was arcing on fuel line, fixed that and still does it.
Possibilities: Dirty MAF- Did have to remove to install new ISV when the problem worsened.
Plugs/Plug wires about 6k on plugs and unknown on wires. Maybe im missing some small thing that could cause this problem, Oh and no know vac. leaks : )
Let me hear your idea's!
thanks
dustin.
1995Qsport is offline   Reply With Quote
Old 04-26-2008, 12:54 AM   #2
Orlando 4000S
Member
Default clogged or bad injector?
Bill
Simply attaching an oversized lawn mower muffler to your '84 Civic does not constitute "Import Tuned"
Orlando 4000S is offline   Reply With Quote
Old 04-26-2008, 05:08 AM   #3
Lago Blue
Default Re: Light throttle hesistation/miss...
...2nd possible dirty MAF sensor.
Lago Blue is offline   Reply With Quote
Old 04-26-2008, 06:30 AM   #4
eldopa69
Banned
Default whens the last time you changed your fuel filter??
eldopa69 is offline   Reply With Quote
Old 04-26-2008, 09:52 AM   #5
1995Qsport
Default Never changed fuel filter, but i dont think thats the problem..
A/F gauge reads Pig rich when it hesitates, maybe if it read lean i would worry about filter, it might be injector ill have to test em. Im gonna pick up some maf cleaner today after work ill let you know the outcome.
Old 04-28-2008, 10:11 PM   #6
dmnderitu
Default Re: Never changed fuel filter, but i dont think thats the problem..
you need to replace the rubber seal between the plastic intake plenum and the intake manifold. Mine was doing the same thing only to find that i had a vaccum leak around there
dmnderitu is offline   Reply With Quote
Old 04-29-2008, 04:49 PM   #7
1995Qsport
Default I have an s3 hose kit.
