Go Back   AudiWorld Forums » Technical Discussion » Motors » 12v V6 Discussion
Old 01-27-2008, 08:50 AM   #1
Judge
Default Just Checking: In a 90CS can I replace the thermostat w/o bumper & Timing Belt removals.
I think there are posts that describe getting to the thermostat both ways. I'd like the easier. One describes it as possible to replace the thermostat with the help of a mirror after removing the serpentine belt. Is that right?
Red 1993 Audi 90CS
Judge is offline   Reply With Quote
Old 01-29-2008, 07:41 AM   #2
odelay12v
Default if its like my 96 a4 12v no
on my car you can put it in service position but you still have to remove the belts
odelay12v is offline   Reply With Quote
Old 01-29-2008, 08:40 AM   #3
quattro90S6
Default you don't have to do any bumper removal on the B4's, jsut take out the fans and you have plenty of..
room. A4's you must remove the front end
__________________________________________________ ______________________________
Do you know where?
AIM: quattro90S6_______________________________________ ___Trek OCLV 9700, nothings original
quattro90S6 is offline   Reply With Quote
Old 01-30-2008, 11:44 AM   #4
Catamount90
Senior Member
Default I think I'm going to have to attempt this as well...
Seems like my nearly-new thermostat is sticking open. I've read that you can slip it by the timing belt but that it's a really tight fit.
Catamount90 is offline   Reply With Quote
Old 02-04-2008, 08:21 AM   #5
Judge
Default Did it! Lessons Learned from Changing Thermostat in 1993 90CS
- If the temperature gauge hardly moves after ten minutes, then the thermostat was to blame.
Old 02-04-2008, 08:23 AM   #6
Judge
Default Lessons Learned - Easy to remove electric fan, obvious bolts and clip
You want to remove the fan, to get room.
You don't have to disconnect the electricity to the fan, just set it aside.
Three 10 mm at top, clips at the bottom.
Old 02-04-2008, 08:26 AM   #7
Judge
Default Lessons Learned - Easy to do the serpintine belt
On the tensioning idler for the main belt, there is a space to insert a large size hex wrench. Insert the hex wrench, then place a two foot pipe on the hex wrench and pull back, this will give you all the slack you need to put on the serpintine belt.
Old 02-04-2008, 08:34 AM   #8
Judge
Default Lessons Learned -- U can change thermostat without removing timing belt, but
U can change thermostat without removing timing belt, but there is not a lot of space to work. I think the engine design is for one to remove the timing belt when getting to the thermostat, but I had fear of doing that, and slowly you can change the thermostat without removing the timing belt.
Also, the thermostat housing does not look like an old school thermostat housing, so you might want to take a look at a picture to have the location and design in mind. The housing is elongated shaped, but the thermostat is located more to the center of the engine. Otherwise you might be deceived to think the thermostat is closer to where the hose exits the engine.
Also there are only two bolts on the thermostat housing, #10. Put a rag into the timing belt area to avoid that a socket falls into that space when you are struggling with the bolts on the thermostat.
Thanks forum for your help.
1993, 90, audi, cs, location, replacement, thermostat
