#1 | ||
1997 A4 1999 A6 Avant |
#2 |
Member
1. The purpose is to realign the sprockets with the belt and crank in case they have moved at all. I didn't do this step during my first TB change with no ill affects.
2. Yes, 8 bolts hold it onto the crank. 3. You cannot remove the belt with the cam bar in place. What I did was turn the engine to TDC, installed the crank lock and cam bar (to make sure everything is aligned), loosen the tensioner, and then remove the cam bar and the timing belt. If the engine is at TDC, the cams should not move.
***** '05 Boxster S (Speed Yellow) '97 A4 2.8Q 12V (Cactus Green) Mods? I got 'em. Baltimore, MD |
#3 |
I bet it will become a lot clearer to me once I see everything during teardown. Just out of curiosity: what was your time from start to finish? I am planning to change W/P and thermostat but I hope that this will not add too much time to the job.
#4 |
Member
#5 |
AudiWorld Expert
![]() 2004 A4 1.8t USP Quattro 6MT K04-15/APR/TT 225 Injectors/Custom Stainless Exhaust/710N/RaceTec FMIC 034 HFC/Jet-Hot Cermi-coated & ported exhaust manifold Spec Stage 3+ with OE DMFW! Neuspeed TIP/Neuspeed Snub/Optima 75-35/AFE Pro-Dry/FSI Coils AMS Short-shift @ %40 redux(Sweet!) ST Coils/ H-Sport Anti-Sway bars/E-codes 19x8.5 OEM Audi Skinny Fives with 235-35 Bridgestone 760 Sport Skins B7 A4 brakes with StopTech Ceramic pads and Stop Tech rotors Sirius Satellite Radio Ross-Tech HEX-USB+CAN Equipped Escort 9500ix |
#6 |
to replace those 8 pulley bolts. My third TB job the stripped to crap.
Maybe a good tip for Barty to have them on hand.
#7 |
Member
However, I have done 3 or 4 other timing belt jobs in between so I've had some good experience with this stuff. ;-)
Thanks for the advice, I'll have to remember that for next time.
#8 |
2001 Audi A4Join Date: Dec 2005
2001 Audi A4 Avant 1.8T Quattro Manual Pelican 1996 Audi A4 2.8L V6 Quattro Manual SOLD |
| Tags |
| a4, b7, belt, job, timming |
