Go Back   AudiWorld Forums » Technical Discussion » Motors » 12v V6 Discussion
Old 04-22-2005, 11:20 AM   #1
Zdrajca Polski
Default A question for people who know about cylinder compression...
I had my compression checked today and it reads as follows: Passenger side cylinders read 150,150,170 and the driver side ones are 100,70,90. My mechanic told me that'd bad. More than likely the 70 and 90 are bad piston rings, and the 100 is going bad. I know the valve stem seals gotta go but is it worth it just selling the car and getting another one. This is coming from a college student who doesn't have $$$. Opinions?
Zdrajca Polski is offline   Reply With Quote
Old 04-22-2005, 11:30 AM   #2
CrazyCab
Default Well depending on what motor you have you could always find a used one in a
Junkyard for a couple hundred bucks and swap it in.
If your running a 12 valve 2.8 liter V6, they are relatively easy to find and somewhat inexpensive.
Better than rebuilding the motor you have, plus if your gonna sell it with a bad motor be prepared to take a big hit in selling price.
CrazyCab is offline   Reply With Quote
Old 04-22-2005, 11:38 AM   #3
KeithS4
Default Depends on the rest of the car
depends the condition of the rest of the car. (and how much you care about it) Presumably you need a car, so it then is a question of if the rest of the car is worth putting the $ into a motor, or will you be spending more to get another car. Also mileage is a consideration. putting $ into a car with high mileage can be a losing proposition - there may be other things that break later.
KeithS4 is offline   Reply With Quote
Old 04-22-2005, 12:00 PM   #4
quattrorally
Default Re: A question for people who know about cylinder compression...
Could also be a lot of carbon build up. you should do a search on seafom.
When I was buying my 90csq my compression sucked (not quite as bad) and after the treatment it went to factory specs !
hope this helps.
Some are here and some are gone:
B6 A4 1.8Tq
B5 S4
B5 A4 1.8Tq
B4 90 12v CSq
Old BMW 318i
Old Honda civic
Very old VW Rabit
Very old Mazda 626
quattrorally is offline   Reply With Quote
Old 04-22-2005, 12:08 PM   #5
CrazyCab
Default Yeah but that would be a hell of a lot of carbon build up
Plus that one cylinder is running at 70 or so, do you think Carbon build up could do that?
Old 04-22-2005, 12:27 PM   #6
Zdrajca Polski
Default I got a bottle of seafoam but...
could the seafoam damage the rings if they're already bad, supposedly. I don't want to make my **** hole any bigger.
Old 04-22-2005, 01:03 PM   #7
moribundman
Default You think the carbon deposists are holding the remnants of the worn rings in their grooves?
I suppose that's possible. :-(
How many miles are on the engine?
A few PSI difference could be attributed to one or a few sticky rings due to carbon buildup, but I'm afraid your numbers go beyond that scenario.
Mhmm, donuts...
moribundman is offline   Reply With Quote
Old 04-22-2005, 03:00 PM   #8
Zdrajca Polski
Default That too i guess. Can it possibly cause damage? That's my main question...
Any estimate on the life of the engine?
Old 04-22-2005, 03:11 PM   #9
moribundman
Default More damage? ***EDITED to correct units!***
I guess, cleaning could actually decrease compression and increase blowby, making things worse.
How's the engine run? How much oil does it burn? How many miles are on the motor?
Minimum compression is ~109 psi. Cylinders may not deviate more than 43 psi from each other.
A leakdown test can pinpoint if rings, cylinders, or if valve stem seals are bad.
Mhmm, donuts...
Old 04-22-2005, 04:07 PM   #10
Zdrajca Polski
Default The engine runs and sounds great...
That's the weirdest thing to me. Burns bout half a quart per week with 151k on the clock. What's a leakdown test. Is it mechanic only. Got a file on how it's done?
