#1 | ||
Junior Member
---------------------------------------------------- "Gregor Voss, your presence intimidates me to the point of humiliation. Would you care to strike me?" --Dieter |
#2 |
How could you tell the coolant was dark? If you used a flashlight and had the blue/green G-11, it may well have looked dark under that lighting. If your coolant looks fine in the expansion tank, don't worry.
And yes, you deserve cookies for that delicate operation performed with your giant freak hands. ;-)
![]() Mhmm, donuts... |
#3 |
Junior Member
Just reminded me of Seinfeld.
Current: 2001 1.8TQMS "AudiWorld picture poster wall hanging parts master"..... |
#4 |
Junior Member
Well, the way I know the coolant was dark is that after apparently splashing some on my new tennis shoes (burnt orange reto new balances!!) I had to run inside and dig out some emergency shoe cleaner. Upon cleaning of the dark oily mess on my left toe I realized my hands were pretty much covered in watery blackened coolant that when I rubbed it with a paper towel behaved more like oil than coolant (i think).
Anyways, my coolant's been looking a little dirty in the tank and the tank is a nasty shade of brown. So this weekend when I get some time I'll try to finally get around to replacing the tank and flushing the system with a handy garden hose.
#5 |
Sounds like you have to flsuh the cooling system. get a Prestone flushing kit and flush thoroughly. Also open the drain on the engine block.
Do you have G11 (green) or G12 (pink) in there right now? If you found some vile stuff, maybe someone mixed G11 and G12. Those two coolants are not compatible and may gel.
#6 |
check your oil to make sure it doesn't look like cappachino (sp?) Otherwise you might be running into a bigger problem than dirty coolant (head gasket going south).
Also, the oil might have been from a leaky gasket, and when you pulled the sensor out, it had oil on it... and then coolant got all over it (and your shoe) and resulted in the mess you had
-Justin Click de sig for more pix ![]() A4: LOTS 'o extras 4000S: MC1, NF head, 34mm exhaust valves, 2871 turbo, 034 Ib ECU, VAP CCK, pro-mounts, and some stiff azz springs! B5 Faq |
