#1 | ||
![]() 1996 A4 Quattro -fixed the gas needle -fixed the climate control display -fixed the sunroof control -relocated the check engine light behind the dashboard so it would stop messing up my nice red gauges ;-) |
#2 |
Member
Replacing the fuel gauge sender is not hard as long at you are comfortable with poking around inside the gas tank. There's a write-up on my website, I think.
***** '05 Boxster S (Speed Yellow) '97 A4 2.8Q 12V (Cactus Green) Mods? I got 'em. Baltimore, MD |
#3 |
Member
Do you happen to have the part number to the fuel sender? My guage has been screwie for a while now. I've already swapped clusters to test, and it didn't fix.
![]() ![]() 2004 Touareg V8 2005.5 A4 2.0T (sold) 1997 A4 2.8 (sold) B7 Oil Change B7 Snub Mount Install Neuspeed Short Shifter Install Votex Rear Diffuser Install |
#4 |
Junior Member
#5 |
Member
You may be able to fix the old one if you have soldering skills. The problem is a bare wire about an inch long that eventually wears and breaks causing intermittent contact. I kept my old sender in case the used one I bought breaks so I can replace the wire.
#6 |
Member
#7 |
Member
| Tags |
| a4, b7, fuel, gauge, number, part, sender |
