Go Back   AudiWorld Forums » Technical Discussion » Motors » 12v V6 Discussion
Old 09-22-2004, 08:14 AM   #1
4g63T
Default What grade Mobil 1 oil should I use? (Grammar???) Car has 150K
916/1000 Galant VR4
The Daddy of all Evo's
itsbull****.net (in the works)
4g63T is offline   Reply With Quote
Old 09-22-2004, 08:20 AM   #2
Mr.D-'97 A4q 12v
Member
Mr.D-'97 A4q 12v's Avatar
Default Mobil 1 5w40 Truck & SUV. Moribundman posted some info regarding this previously.
The Truck & SUV designation is just poor marketing.
'05 Boxster S (Speed Yellow)
'97 A4 2.8Q 12V (Cactus Green)
Mods? I got 'em.
Baltimore, MD
Mr.D-'97 A4q 12v is offline   Reply With Quote
Old 09-22-2004, 08:30 AM   #3
moribundman
Default Where are you? Cold winter coming?
If you use the Mobil oil finder on the Mobil website, you will find that no Mobil oil meets the recommended viscosity and the required VW/Audi oil specs. Mobil will say you may be able to use M1 0W-40 or M1 15W-50.
In my opinion, M1 5W-40 (idiotically marketed as "Truck&SUV") is the best M1 choice for the 12 engine, as it offers a near ideal viscosity range. Be advised that this oil does not carry the required VW/Audi approvals. However, this does not mean it does not meet or exceed the requirements of the 12v engine.
If you expect sub-frezzing temperatures, you may want to go with M1 0W-40. My engine didn't sound good once hot with that oil, though. Lots of rattling, which I don't hear with M1 5W-40.
You have other oil options (VW502.00):
Castrol SLX 0W-30 (make sure it says it meets VW 502.00, not all SLX say that!)
Castrol 5W-40
LubroMoly Vollsynthese 5W-40
Pentosynth 5W-40
Chevron 5W-40
Mhmm, donuts...
moribundman is offline   Reply With Quote
Old 09-22-2004, 08:33 AM   #4
moribundman
Default Yes, yes I did...
and I still do.
Now we can get the VW502 spec in the Belgian Castrol 5W-40. Nice, because A, it meets the specs, and B, because they dropped the ca $8 price to under $5 a quart.
From seeing the VOA (virgin oil analysis) on that oil, I'm inclined to say that M1 5W-40 is a better oil, though.
Mhmm, donuts...
Old 09-22-2004, 08:37 AM   #5
quattro.pilot
Elder Member
Default M1 15w50 is a great oil! isn't as thick as you'd think. but for cold operations I'd go thinner...
any of the 5w40's is sufficient.
otherwise most of the oils don't meet VAG valvetrain requirements... hence ticky lifters etc. My lifters are already shot as I believe they're 11 years old, but if you replace 'em run the proper oil & they'll be good for a long time
check yah later
I poz'd my neg.
audi 5000 yo
quattro.pilot is offline   Reply With Quote
Old 09-22-2004, 09:15 AM   #6
moribundman
Default Lifter tick
... has to do with how fast or slowly the lifters fill with oil, which is mostly a matter of viscosity. For example, when hot M1 0W-40 made my motor's valves clatter when hot. That's why I didn't care for the 0W-40. It's thin sauce.
The pertinent valve train wear test is PV-5106.
Here are the required tests and specs to pass VW 502:
sulfated ash: 1.5% max
HTHS: 3.5 min
seal compatibility: PV-3344
valve train wear: PV-5106
VW T4 test: PV-1449
sludge: M111E
The VW 502 spec requires very demanding high temp/high load testing in a test that runs for 248 hours -- with no makeup oil added.
Mhmm, donuts...
Old 09-22-2004, 12:16 PM   #7
quattro.pilot
Elder Member
Default heheh, i was wondering if I'd get caught for the lifter comment =S
I poz'd my neg.
audi 5000 yo
Old 09-22-2004, 03:39 PM   #8
moribundman
Default I'm pretty sure the valve train wear test concerns the lobes
Cam lobes, not ear lobes! ;-)
Mhmm, donuts...
Old 09-23-2004, 07:21 AM   #9
odelay12v
Default Re: Yes, yes I did...and the m1 5w 40 is that the dino or syn?
odelay12v is offline   Reply With Quote
Old 09-23-2004, 09:20 AM   #10
Mr.D-'97 A4q 12v
Member
Default Syn
Mods? I got 'em.
Baltimore, MD
150k, 502, 5w40, car, finder, galant, grade, mobil, mobil1, mobile, oil, org, vr4, vw
