Go Back   AudiWorld Forums > Technical Discussion > Motors > 12v V6 Discussion
Old 06-26-2004, 01:08 PM   #1
moribundman
Account #: 50038
Default Is the oil pressure relief valve in the oil pump?
Mhmm, donuts...
moribundman is offline   Reply With Quote
Old 06-26-2004, 01:34 PM   #2
moribundman
Account #: 50038
Default UrS4...
The oil pressure relief valve should not allow excessive oil pressure, whether the filter bypass valve is open or closed, or am I mistaken?
Mhmm, donuts...
Old 06-26-2004, 09:22 PM   #3
eep
Account #: 74028
Default Re: Is the oil pressure relief valve in the oil pump?
Nope ... it's part of the oil pickup assembly on the AFC engines.
eep is offline   Reply With Quote
Old 06-26-2004, 10:32 PM   #4
moribundman
Account #: 50038
Default I should have known you had some pertinent info on your site. Thanks!
Mhmm, donuts...
Old 06-27-2004, 06:20 AM   #5
VAP
Account #: 711
Default there's at least one other known pressure-relief valve...
used in the AAH/AFC engines in the cylinder heads that regulates oil pressure in the lifter oil gallies in each cylinder head.
And there's another one under the valley pan tho I can't tell from the diagram if either are addressed via it's circulation layout.
One things clear... these engines have a lot of in-line oil pressure reliefs going on. Way more than any other engine I'm personally aware of. Great when they work... a potential nightmare if/when any one fails. And everything mechanical will fail.
VAP is offline   Reply With Quote
Old 06-27-2004, 10:17 AM   #6
moribundman
Account #: 50038
Default That's a little scary
I've had the occasional low oil pressure on previous cars, but I've never had too high oil pressure. I suspect our oil pressure idiot light won't come on if the pressure is too high...
Mhmm, donuts...
Old 06-27-2004, 04:47 PM   #7
eep
Account #: 74028
Default Re: there's at least one other known pressure-relief valve...
Good call! I never think of the two valves in the head. You can't tell from the picture, but the hex part of the valve is connected to the rest by an extremely thin bit of metal - so thin, in fact, that you're just as likely to twist the head off and have a nice smooth hole in your head than remove the valve. Nice. The valve on 30v engines has a Torx head embedded in the valve body instead, much nicer.
So: oil pressure relief valves:
- 16 bar (232 psi) in oil pickup assembly
- 11 bar (160 psi) safety valve, only opens at high RPM and cold engine temp; AFC only
- pressure relief valve, *cough* in the oil pump
- now in the engine; there are the pressure valves Mance mentioned, one on each head. Those control top-end oil pressure.
- there are two oil check valves in the steadying chamber (under the valley pan), but those don't really do much in terms of pressure control; they just keep oil in the lifters when you shut the engine off.
There's also some pressure control done by the head gasket - each one has a finely-tuned obstruction to oil flow that maintains oil pressure in the engine block when the oil pressure relief valves are open.
Old 06-29-2004, 06:23 PM   #8
eep
Account #: 74028
Default The poop on engine lubrication
If anyone is still reading this thread (and cares), I've put a bit more detailed information on the engine lubrication setup at 12v.org:
Old 07-01-2013, 10:41 AM   #9
lostroot1
Account #: 261205
OK so im a little confused...I have an AHA (99 2.8 A6) do i have a relief valve?
here is my problem: when the engine is cold the oil pressure is perfect through the RPM range ( checked with mechanical gauge) but when the engine gets to normal operating temp the oil pressure drops at 1500-2000 rpm then shoots back to normal. It has a new oil pump and full Syn oil in it, and a OEM Mann filter.
lostroot1 is offline   Reply With Quote
Old 07-01-2013, 02:51 PM   #10
CRAZY_RUSSIAN
Account #: 153887
CRAZY_RUSSIAN's Avatar
run some seafoam in your oil for about 200 miles, about 1/3 of a can
1993 Audi 90CS Quattro (loving it)
*(suspension and brakes)034 derling control arm bushings + alum-subframe bushings, 034 street density trans mounts+JHM SOLID” Short Throw shifter. B5 rear sport swaybar, B5 upper a-arms, solid VAP shock mounts + B&G springs + Bilstein sport shocks. EBC 3D front rotors + EBC green pads front and rear. 17" ASA's, head lights, aux gauges. blue plasma instrument cluster, A4 3 spoke steering wheel.
*(engine)replaced a motor at the end of 2008, gasket matched heads, ARP head studs, air box velocity stack, 4 to 3 wire MAF conversion, 18.5lbs flywheel with SPEC stage 2 clutch.
1975 VW bus (gone)
1973 VW Super Beetle (what was i thinking?)
1968 VW Bug (my pride and joy)
*2.5 inch front drop and disk brake conversion, *2110cc motor (in progress)new wiring harness,3 inch wider fenders all around, 195/45r15 front and 195/65r15 rear tiers
1991 GMC Sonoma RWD, manual, 4 banger (gone)
1979 Suzuki GS750EN with 31k original miles
1981 Suzuki GS750L (will be on a chopping block for a bobber)
1981 Yamaha XV920
1983 Yamaha XV750 (for g.f.)
1985 Dnepr MT10-36 (stolen)
1992 Dnepr MT11-32 (also stolen)
CRAZY_RUSSIAN is offline   Reply With Quote
1994, 2005, a4, a6, aah, afc, audi, check, oil, pan, pressure, regulator, relief, urs4, valley, valve, valves
Forum Jump
