Go Back   AudiWorld Forums » Technical Discussion » Motors » 12v V6 Discussion
Old 08-13-2003, 05:10 AM   #1
VAP
Default New Magnaflow 2-into-1 3" Hi-Flow cat with 2.5" exhaust system installed
This pic is of the old sytem removed, new rear O2 sensors routed and new exhaust ready to be installed.
The new system is fabricated from all mandrel bent aluminized steel tubing. Mandrel U-bends were purchased and cut to size so that every joint is a welded slip-fit "male-into-female joints from front to rear. All cuts were smoothed internally with a die-grinder before being welded. I opted to not use stainless initially as if it didn't work I didn't want to have to cut it all out and toss it.
VAP is offline   Reply With Quote
Old 08-13-2003, 05:20 AM   #2
VAP
Default Pic 2:
Here's the new cat with the 2-into-1 collector sleeve installed. Also the 3"-to-2.5" outlet cone that was pressed from the same die I use for making velocity stacks.
Took over 3 hours just to get this part test-fitted and made as there was a ton of clearance and alignment issues to deal with.
Old 08-13-2003, 05:24 AM   #3
VAP
Default Pic 3:
The new cat being held in place by a muffler stand while SS flex joints are installed and everything aligned just before removing once more, installing dual O2 sensor bungs and welding it all into place.
Old 08-13-2003, 05:29 AM   #4
scott12v@pghaudi
Default What rear muffler are you going to use?
I'm going to have TDL redo mine (the original Vortrag system has alot of leaks and never was really right). And I'm probably going 2.5" (I've found that PA roads and hills are not very forgiving with a 3" system).
However, looking through the Magnaflow website, I haven't found a single rear muffler with tips that has a 2.5" inlet. I just started my search yesterday, but I would have thought that a rear muffler with 2.5" inlet and dual tips would be pretty common.
Thanks,
Scott
scott12v@pghaudi is offline   Reply With Quote
Old 08-13-2003, 05:38 AM   #5
VAP
Default Pic 4:
The system fully installed. I opted for a small muffler instead of a true resonator as I've heard all the stories on how loud the Magnaflow components are. And even with dual mufflers and 2.5" pipe it's still too loud for my tastes but only by a little. When I fabricated the system I provided for a straight-thru resonator to live just aft of the cat by putting an extra joint in which I could cut out later and replace with the resonator if it was too loud. I'll get back to that in a few days.
Driving impressions: Louder of course and I forgot to tighten the O2 sensors before driving away so I'll be on my back under each side of the car this morning doing that.
And somethings just not quite right torque-wise. It's slower to climb to redline in spite of being a far freer flowing and less restrictive system. I have a constant CEL due to my EGR valve "insufficient flow" code so I don't know if I threw any other codes with the installation due to the perpetual CEL from that. I'll pull codes this morning see if there's anything obvious or if the computer simply needs to be reset. I only have 3.7 miles on it driving from the muffler shop home. Today I should be able to clear it all up other than the loudness issue and see what I've really done/created be it silk purse or sow's ear.
Old 08-13-2003, 05:42 AM   #6
VAP
Default Magnaflow single 2.5" inlet with dual 3"x2.5" angle-cut, oval, rolled outlet tips.
I'll get a pic up of the tips later today
Old 08-13-2003, 05:45 AM   #7
scott12v@pghaudi
Default Does it look like this one?
This is exactly what I want, but the online magnaflow catalog doesn't have a listing for this muffler with a 2.5" inlet.
Old 08-13-2003, 05:46 AM   #8
scott12v@pghaudi
Default Nice job BTW.
I never thought about going with a single cat like that.
Old 08-13-2003, 05:49 AM   #9
VAP
Default thats EXACTLY the one. And I found it in-stock locally with a 2.5" inlet so it's definately....
available. Maybe Magnaflow's website hasn't been updated in awhile.
Old 08-13-2003, 05:54 AM   #10
Mr.D-'97 A4q 12v
Member
Mr.D-'97 A4q 12v's Avatar
Default Do you think going with a single cat vs. dual cats will have any affect on emissions? MD standards
are pretty strict. Great job BTW! I never even thought about adding a resonator in combination with the two mufflers to quiet it down more. I may consider that.
'05 Boxster S (Speed Yellow)
'97 A4 2.8Q 12V (Cactus Green)
Mods? I got 'em.
Baltimore, MD
Mr.D-'97 A4q 12v is offline   Reply With Quote
12198, 25, 28, 3, audiworld, collector, ito, magnaflow, sc400
