#1 |
#2 |
Junior Member
#3 |
Turns out 6061 aluminum doesn't like to be cold-swaged to this extreme. I split 4 of em right down the side before I gave up trying to get the angle I wanted. And since so much hand holding of the part is neccsary I cant do em hot either. So I annealed em with a torch to about 800-900 degrees and let em cool on their own without quenching. That seems to work just fine, making them far more maleable. You can see how the oxy/acet torch soots em up and heat discolors em with the O2 turned off when torch annealing. I'll fire up my plating oven later when I have a number of them cut to size so I can do 30-40 at a time. Next I'll true em up on the lathe and get the exact inlet contour and flat base then de-burr and high-speed finish them on the lathe with rouge until they appear like liquid mercury and everyone should be pleased with the fit/finish. |
#4 |
Elder Member
#5 |
Junior Member
... that you were going to put eight 3" tailpipes on your A4! I figured you'd look like Super-Rice or a mini-scale Patriot missile launcher! ;-)
Bob K. |
#6 |
that had a reinforced breech area 6" thick tapered to a 2.5" barrel. Thing launched potatoes over a mile at 3270 feet per second at a 4,700 psi compressed air charge. Was a fun project but the air pressures are a little scarey to deal with. And I still lost the distance contest by over 700 meters. Win some lose some. The secret is good ammo. Most spuds disintegrate 18" outta the muzzle.
#7 |
#8 |
Junior Member
#9 |
Junior Member
#10 |
Elder Member
