#1 | ||
03 Atlas Grey Allroad RNS-E retrofit Audi OEM Bluetooth retrofit partktronic retrofit DLO HOME DOCK Deluxe Ipod Kit Boyocam rear view cam Milltek Exhaust RS6 18" Replicas Tip |
#2 |
Sebastian @ Ross-Tech.com |
#3 |
Any chance you can help with the measuring blocks? Which one corresponds to the tip button.
--------- its a "618" which was what this article mentioned would work http://nsxjr.com/docs/MFSW.pdf From VAGCOM ---- Address 01: Engine Labels: 078-907-551-AZA.lbl Part No: 4Z7 907 551 S Component: 2.7L V6/5VT G 0020 Coding: 07755 Shop #: WSC 01029 WA1YD64B93N001011 AUZ7Z0B2141391 1 Fault Found: 17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground P1454 - 35-10 - - - Intermittent Readiness: 0000 1000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 4Z7-927-156.lbl Part No: 4Z7 927 156 M Component: AG5 01V 2.7l5VT USA 2122 Coding: 01032 Shop #: WSC 02325 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: None Part No: 4Z7 907 389 A Component: ABS/ESP allrad D55 Coding: 06497 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: Redir Fail! Part No: 4B0 820 043 AD Component: A6-Klimavollautomat 0105 Coding: 00010 Shop #: WSC 02325 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: None Part No: 4Z7 959 655 J Component: Airbag 8.4EP 2000 Coding: 0000607 Shop #: WSC 02325 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4B0-907-487.lbl Part No: 4B0 907 487 H Component: Lenkradelektronik D01 Coding: 01015 Shop #: WSC 12345 No fault code found. ----------------------
#4 |
just curious.
#5 |
Im retrofiting this so I need to know what it should say as the tip buttons are not working despite new 618 module and wiring to Tip Selector.
The only thing not done yet is a new slipring but TeddyBgame seems to think I dont need it (Im upgrading from the 6 button MSFW to 6 button + tip MSFW)
#6 |
It's probobly not related to the tip shift inop. Stock is Y=0.
#7 |
is for PN 1J0 959 654 M, none of the other PNs for the slip ring say anything about the tip controls on the wheel, the others only mention the MFSW and or heated or leather.
| Tags |
| 1j0, 1j0959654m, 654, 959, add, audi, log, msfw, tiptronic, vag |
