Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 03-20-2007, 06:53 PM   #1
A4skinny
Default Help with codes pls...
I've replaced the cluster in my 2000 s4 tip, and keep getting these two codes i've searched the forum and haven't had any luck i'm assumig that the cluster is the problem but want to be sure before i send it back. here is the log.
Thursday,08,March,2007,18:08:19
VAG-COM Version: Release 607.2-UD
Control Module Part Number: 8D0 907 551 B
Component and/or Version: 2.7l V6/5VT G 0004
Software Coding: 06651
Work Shop Code: WSC 06325
2 Faults Found:
18098 - Malfunction Indication Light (K83): Electrical Malfunction
P1690 - 35-10 - - - Intermittent
18084 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
P1676 - 35-00 - -
Readiness: 0110 1101
thanks in advance...
A4skinny is offline   Reply With Quote
Old 03-21-2007, 05:15 AM   #2
Theresias
Theresias's Avatar
Default Looks like the new cluster is not compatible...
Sebastian @ Ross-Tech.com
Theresias is offline   Reply With Quote
Old 03-21-2007, 05:20 AM   #3
A4skinny
Default Re: Looks like the new cluster is not compatible...
Thats strange the cluster came from the dealer and my #vin was used to order it. I guess i'll find out when i replace it again.
Old 03-21-2007, 05:28 AM   #4
Uwe@Ross-Tech.com
Audiworld Premium Sponsor
2006 Audi A3
Uwe@Ross-Tech.com's Avatar
Default What are the original and new cluster part numbers?
http://www.Ross-Tech.com
Uwe@Ross-Tech.com is offline   Reply With Quote
Old 03-21-2007, 08:29 AM   #5
Bracketracer
Default I've also come across this issue on an '00 A6 2.7t
however, my customer was not willing to pay for the diagnostics to root out the problem. I can clear the codes, and sometimes they come back immediately, while other times they'll take a week. Both codes come up as intermittent.
Bracketracer is offline   Reply With Quote
Old 03-21-2007, 11:20 AM   #6
A4skinny
Default Re: What are the original and new cluster part numbers?
i no longer have the old cluster, as it was returned as a core, the dealer has ordered another and it should be in this week, i will follow up when it arrives.
Old 05-25-2007, 08:14 PM   #7
A4skinny
Default Answer.....
digging up this thread to solve my own question and hopefully help anyone else who might run into this.
after getting ready for a bosch to hitachi maf conversion i came across some info on cluster recoding and noticed that audi s4's from 2000 to 2001 and cars from 2001.5 to 2000 use different maf sensors each with its own softcode for the cluster, the code for 2000 to 2001 was 0 and 2001.5 to 2002 was 1025. bosch maf=0 hitachi=1025, anyways my car being a 2000 the soft code should be 0, but after checking with my vag code showed 1025, changed code to 0 and bingo epc light goes off. I'm assuming that each maf sensor has different voltage signal wich would give a code if they were looking for the other. Well i hope this helps someone out took me two months to figure it out. lol
also the link below on how to do the procedure courtesy of s4Wiki
01, 2000, 42, a6, audi, b5, code, p1676, p1690, ross, s4, tech
HTML code is Off
