VAG-COM Discussion
remote doesn't work and 01330 fault code
Old 01-14-2006, 11:27 AM
pasprobe's Avatar
Default remote doesn't work and 01330 fault code
I have a a4 2002 1.8T, I replace the car battery 3 month ago and since that my remote (both)stop working (but they work just fine before I change the battery). If I vag the car I got
01330 central control module for convenience
37-00 faulty
I went to stealership and pay 100$, after 1 hour of work they said that they don't know what is the problem....
I tried the programming procedure, it didn't work.
I need your help know, because I realy need to get it work. I have two kids and I need to go put the keys on the switch each time I want to sit kids in car.
Old 01-14-2006, 11:29 AM
Always Overcharged's Avatar
check that the soft coding is ok
Old 01-14-2006, 11:55 AM
pasprobe's Avatar
Default Re: check that the soft coding is ok
I'm new with vag-com.
Can you tell me what code I'm suppose to check or have and where.
Thanks
Old 01-18-2006, 04:04 PM
pasprobe's Avatar
Default need some help please
Please tell me what I need to do to have my remote working.... I'll love to go at the dealer and say man I find the problem...
Thanks
Old 01-19-2006, 09:55 AM
Default you sound like you have an immobiliser issue
check the soft coding in the cluster -dealer should know what yours should be -and go from there
TTransport
TT (Mk1) Discussion
01-24-2009 11:41 AM
rookie18
05-10-2006 06:49 AM
scottyb971.8t
09-29-2003 01:02 PM
Quick Reply: remote doesn't work and 01330 fault code
