Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 04-20-2005, 06:05 AM   #1
UnoDosTurbosQuattro
Default X-Post-ish. Allroad with suspension height imbalance, 402 VAG changes not sticking.
2001 allroad, Key-Com interface, VAG release 504.0-D
Trying to use 402 mod to even out my suspension height at all 4 corners...
Left side wheels are dead-on, right rear is higher by 0.5 to 1 inch, and right front is also high but only by 0.25 to 0.5 inch.
Have made 402 adjustments several times to try to even things out. Adjustments seem to work well on all corners except the right rear. Maybe I'm doing something wrong? To summarize the procedure I used:
- engine off, key on
- go to level control module 34
- log in
- enter adaptation, got to channel 1
- wait for level 1 / level 2 cycle, then "ready"
- enter ch 1 value, test, save
- repeat for ch 2-4
- enter 01 for ch 5, test, save (ERROR)
- done, go back
What should I do next to make sure the new settings are locked in?
- back out of the module?
- change heights to test?
- turn on the engine?
- other?
Also, I monitor measuring block 4 and the four settings are never all at 0.0mm when in level 2. Right/Left sides are always off at least 3mm from each other.
If all 4 corners are balanced equally, should the 4 measuring block values match up at each level setting?
About 6 months ago, a very well reputed mechanic who does a lot of Audi work accidentally put my car on a chassis lift without using jack mode...I'm wondering if this could be contributing to the problem.
2001 allroad 2.7T tip; Premium, Cold, Platinum/Black,
18" RS6 reps w/Dunlop SP Sport 5000,
Stock twinspokes w/Dunlop Wintersport M3,
H-Sports (hard), Phatnoise, Thule racks
2007 A3 2.0T, 6sp Manual, Lava Grey
S-Line, RNS-E Navigation, Cold, Technology Packages
UnoDosTurbosQuattro is offline   Reply With Quote
Old 04-20-2005, 06:25 PM   #2
Uwe@Ross-Tech.com
Audiworld Premium Sponsor
2006 Audi A3
Uwe@Ross-Tech.com's Avatar
Default At what point are you making the measurements
which you're feeding into the adaptation channels?
-Uwe-
http://www.Ross-Tech.com
Uwe@Ross-Tech.com is offline   Reply With Quote
Old 04-20-2005, 11:34 PM   #3
want
Default My answer...
want is offline   Reply With Quote
HTML code is Off
